Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - HEI distributor problem.
Old 10-09-2012, 04:52 AM
staleg's Avatar
staleg staleg is offline
Last journal entry: Home made gear stick
Problem seems to be solved.
The ignition module wasn't fastened. It was just laying loose and held in place by the wires and the fact that there isn't much space around it.
The two missing screws are also grounding the module.
This is how the module was out from the box.
Will contact Pertronix support an ask if the can send new screws.
