Hei Distributor problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-07-2012, 04:29 PM
chuck M's Avatar
Ok guys i have no idea what i did to my accell distributor to make it all of the sudden stop creating spark. It started by me pulling the distributor out of my seventies something sbc 350 to reset it because it was one tooth off. I set tdc with timing mark on zero on compression stroke and pointed the rotor towards the number 1 cylinder. Pluged in all the connectors reinstalled cap and no spark. The truck ran great with no problems 10 min earlier i just wanted to get it one tooth over to properly time it with a light. I just dont know what could have happend , I checked all wires and they look good. There is power going into the connector marked BAT. Any ideas would be greatly appriciated. Thank you
Old 10-07-2012, 04:58 PM
What kind of distributor is it. HEI or points style? If it is a HEI you may have a bad module. ACCEL 35361 - ACCEL Ignition Control Modules - Overview - SummitRacing.com If it is a points style it may have a bad condenser.
The Following User Says Thank You to cdminter59 For This Useful Post:
chuck M (10-27-2012)
Old 10-07-2012, 05:32 PM
chuck M's Avatar
Accell HEI
Old 10-07-2012, 05:47 PM
chuck M's Avatar
How would i go about testing the module?
Old 10-07-2012, 08:01 PM
Silver Surfer's Avatar
Advanced User
Last journal entry: bwaahhaahahaaahhaa
Per the Wiki:
Module:
Many parts stores can test the HEI ignition module at no charge. If that isn't possible, another way is to replace the module ith a known good module.
The Following User Says Thank You to Silver Surfer For This Useful Post:
Old 10-07-2012, 10:12 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
You DID replace the rotor, right?
The Following User Says Thank You to cobalt327 For This Useful Post:
Old 10-08-2012, 05:29 AM
chuck M's Avatar
I have not replaced anything yet. Was wondering if I should just scrap the accel setup for a MSD HEI
Old 10-08-2012, 08:22 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
What I meant was, did you put the rotor back on the top of the dist. before replacing the cap. No rotor = no fire.
Old 10-08-2012, 07:17 PM
chuck M's Avatar
Yes the rotor was in. Went to the parts store today and bought a module started right up. I am very amazed that it decided to go bad in the 10 min that i had the distributor off. Never dropped it or anything. Thank you all for your input. Love this forum.
Old 10-08-2012, 07:22 PM
If I were you, I'd keep a spare module in the glovebox as long as you have the Accel distributor. Mark my words.
ssmonty
The Following User Says Thank You to ssmonty For This Useful Post:
Old 10-08-2012, 07:46 PM
I am glad the module was all the problem. Sometimes it doesn't take much to short it out. When you installed the new module did you use heat sink compound on the bottom of the new module? Keeps it from overheating.
Old 10-09-2012, 10:20 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
X2 on the heat sink compound. You will sometimes hear to use dielectric grease. This is prolly better than nothing- but it is not the right thing to use. More here.
Good luck and glad you figgered it out!
Old 10-09-2012, 07:46 PM
chuck M's Avatar
I used grease because it came with the module. Should i use something different
Old 10-10-2012, 07:41 AM
Yes ,it is called heat sink compound. Advance Auto, Radio Shack, and Auto Zone all carry small tubes of it. It is used on computers too so a computer store may carry it.
Old 10-10-2012, 09:34 AM
chuck M's Avatar
Awesome thank you
How do you remove the distributor gear on an HEI distributor? against all odds Hotrodding Basics 4 01-31-2012 09:58 PM
HEI Distributor problems usa3990 Electrical 3 09-16-2010 03:42 PM
stock HEI to Small body HEI now there's problems, need help Doc fat50chevy Electrical 6 07-13-2006 03:19 PM
hei distributor aceofspades49c Engine 8 05-01-2006 01:06 PM
HEI Distributor wally Electrical 4 05-18-2004 03:36 AM
