hei distributor question - Hot Rod Forum : Hotrodders Bulletin Board
Old 03-14-2008, 10:08 PM
Casperdude898's Avatar
alrite i got this used hei distributor for my truck it has the 4 wire connector and i dont have the connector and i heard you can twist two of the wires together and not have to plug it in. there is two black wires a green one and a white one and a guy at work told me he thinks its the green and white wire does any one kno?
Old 03-15-2008, 07:42 AM
Jmark's Avatar
When you say a "4 wire connector", are you saying there is a seperate harness coming from the dist. that has a flat plug with 4 connectors in it? If so, that is an HEI that is designed for an early computer system. I've never heard of twisting certain wires together to make it work. Not saying it can't be done, but an earlier HEI would be better suited for a non-computer application. New ones can be had for under $60 on eBay. I personally have bought 2 of these and and very pleased!
Mark
HEI ignition and 700r tranny kycsomc Introduce Yourself 2 02-22-2008 01:13 PM
GM HEI Module Keeps Burning Out ripvanhalen Electrical 6 09-24-2007 11:28 PM
Ford HEI csracing Engine 2 12-03-2006 07:06 PM
Do I Need Little HEI Box for New HEI Dist? Mr.56Chevy Electrical 0 12-23-2002 02:38 PM
Power to HEI Seon Electrical 3 09-27-2002 03:03 PM
