hei distributor question - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-03-2011, 08:09 AM
Has anybody in here ever used one of the hei distributors they sell on ebay for around 40 bucks?
Old 08-03-2011, 09:29 AM
helrazr3's Avatar
im on a highway to hell
Last journal entry: new wheels and seats
do you mean a used one? i pick up a used hei any time i run into a chevy with points. but i usually get them local at a salvage yard. never had a problem with one
Old 08-03-2011, 10:50 AM
I purchased what was listed as a High Performance Dizzy off Ebay last year for $40 bucks NEW and I had nothing but problems with it. I'm not sure why but I got timing readings all over the place from it. That could be just my experience.
Old 08-03-2011, 11:16 AM
the ones i saw were new ones listed as super 65k.
Old 08-03-2011, 11:50 AM
helrazr3's Avatar
what do you have for a motor?
Old 08-03-2011, 01:49 PM
One for a Ford 302. You want it? It's sitting beside my desk. I recurved it and went on a 200 or so mile trip. The longer I drove, the worse it detonated under light throttle. After we got home I took it for a 1/4 mile test and it ran like garbage afterwards - misfiring as if the spark was scattering above 3000 rpms. I put 2 and 2 together and decided the only thing to cause all of this was the dist shaft grinding down into the distributor which would cause the magnet to hit the pole piece causing the erratic fire AND advance the timing by rotating the shaft forward as it lowered. I pulled it out and BINGO. The shaft ate the top bushing causing it to drop about 1/8 inch. It may have 500 miles on it total. Luckily I bought it as an experiment and tossed my Mallory back in it.
Old 08-03-2011, 01:51 PM
Oh, yeah, to add to my story above, timing was erratic as hell varying 5 or more at idle. The Mallory you can't tell the engine is running with the timing light.
Old 08-03-2011, 02:02 PM
Its for a 350 chevy
Old 08-03-2011, 02:11 PM
KMATCH your story sounds exactly like mine....
Old 08-03-2011, 04:05 PM
cool rockin daddy's Avatar
You get what you pay for, OP. I wouldn't put one of those in my engines. EVER. The distributor works with the camshaft to time your engine and provide the spark at the right time. NOT a place to bargain hunt.
Old 08-03-2011, 11:40 PM
dinger's Avatar
I've bought 2 from a guy in Canada, Ebay, rebuilt, worked like a charm, decent price, IIRC about $65 complete with cap.
"When I was younger, I could remember anything, whether it had happened or not." - Mark Twain
Old 08-04-2011, 03:27 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
There have been reports (link supplied by artsvettes on another thread) of some imported HEI replacement distributors burning up the cap and rotor due to a high resistance center contact that passes the current from the coil through the cap to the rotor.
There are also several threads on the imported vs. name brand parts including distributors. Here's two:
Skip White 65,000 Volt Distributor Revealed
Pro Comp: Junk?
Old 08-13-2011, 09:55 AM
Two8tyThree's Avatar
Last journal entry: Picture of delivery
Get rid of the Chinese module, they are crap. I put a GM module in for my neighbours Chevelle (he bought a Chinese dist for it off ebay) and it fixed the timing wander. Also check the pickup coil magnets make sure the points on the magnet are spaced properly, might be an idea to change the pickup coil too.
I also had to recurve the mechanical advance with a HEI advance kit (and a bit of precise grinding to the advance cam under the rotor).
Old 08-13-2011, 01:12 PM
Just start with an original GM unit and rebuild it with quality parts, you'll be mile ahead.
I know too many people who have these cheap HEI knockoffs hanging on the garage wall because they are crap.
Old 08-14-2011, 12:59 PM
i have one in my 355 sbc and it turns 6000+ rpm and have never had a bit of problems
distributor question jollyrogger Engine 1 05-07-2008 02:24 PM
hei distributor question Casperdude898 Engine 1 03-15-2008 07:42 AM
SBC distributor question Steve-0321 Engine 2 03-12-2004 09:39 AM
Distributor question Indian Engine 1 08-22-2003 07:02 PM
Distributor Question BruceZ28 Engine 0 01-21-2003 03:05 PM
