HEI distributor and TPI
Can I convert my old HEI distributor to work with a TPI setup. I've noticed that some TPI's have HEI distributors while most have external coil setups.
SOME ONE ANSWER THIS MAN...!
yeah i need to know if you can use 4 pin HEI with TPI as well.
I will be using a SD ECU (90-92). Can this be ran with a TPI HEI?
How do the distributors differ (physically/visually) between the ESC and non-ESC distributors? Can I use the cap/rotor/coil assembly from my old distributor with a TPI HEI? I recently upgraded my HEI with all MSD components. I also have a new TPI module and main distributor body with PU. |
For the price of new distributor, personally I wouldn't cut any corners with a cheap rebuild. Especially trying to convert an older HEI to have late model computer control.
You can get a MSD knock-off from Procomp Electronics for $90. I bought one for use in my Camaro using a Holley C950 ECM. It uses the late model, small cap, remote coil HEI style distributor. This will plug into your SD (90'-92') 7730 ECM harness. The Procomp distributor pictured below is a nice billet piece and comes with cap and rotor. Get it at Fastengineparts.com I use an MSD #8207 E-coil mounted to my firewall, but if you are retrofitting a TPI system, get a stock or MSD coil and mount it in the stock TPI location. Fastengineparts.com also sells a nice, economical holddown tab. If my memory serves me correct, it was less than $10 with a stainless stud/nut. Best of luck, Ed www.edgesz28.com BTW www.mycommitment.com
SOLD!
Thanks edge. I should be able to get more than that for my reman. w/ MSD components on ebay. |
