Hei Dizzy How To Wire Up Questions From Noobie - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-22-2007, 09:25 PM
keithholden's Avatar
New Member
Hi I have a HEI on my 350chev its in a holden car which I found out has resistance in the wiring loom from the 6 cylinder engine and standard coil it use to run..
I have only got 1 wire Red and white coming from the dizzy and the car runs fine when this is put to the battery. But runs crap when I connect to the old wires. The car is 1974.
To wire this up my mate said he thinks the dizzy should have an earth is this correct??
Whats the recomended way to wire this to my car, any advice appreciated
Ive read stuff on the dizzy but it didnt have about the hook up procedures.
Cheers Keith.
Old 09-22-2007, 09:45 PM
Wiki Edits: 31
HEI needs consistant 12v. need to get 12v switched. most GM's have a ignition hot unfused circut you can tie into, or use your 6v resisted wire w/ a relay
Old 09-22-2007, 11:15 PM
New Member
Earth
HI do I need to hook up an earth wire to the dizzy as well..
I only have the one wire coming out
Old 09-22-2007, 11:20 PM
Kevin45's Avatar
Just one of the guys
Last journal entry: Vise jaws
Your "earth" or "ground" as we call it here is done through you block. It is grounded when it is inserted.
Electric choke voltage Mertz Engine 36 04-22-2007 11:28 AM
Wire Looms for 350 HEI with rams horn manifolds Jag Daddy Engine 8 03-17-2003 07:25 AM
Chevy Ignition questions Camaro2Fast4u Engine 1 03-05-2003 01:36 PM
HEI plug wire placement RodneyUSAF Engine 2 03-04-2003 06:34 PM
57 Chevy generator to altenator swap Rodrunner Electrical 2 07-17-2002 09:59 PM
