I don't see how that could affect the advance since the fat part swings out not the slim one
I just checked two of my HEIs and neither has anything in those holes. Someone must have added that, but I can't understand why. |
I haven't looked, but maybe they go all the way thru and stop it from the bottom? it doesn't seem to rotate as far as it does in that HEI writeup on rustpuppy.com
my weights don't swing out nearly as far.
distributor
The advance slot on the underside of the weights was probably shortened limiting the amount of advance....
My question is why are you looking for more then 12 degrees of mechanical???? Keith |
Check to see if the mechanism is sticking on the shaft (underneath), sometimes a bit of emery cloth will free it up. Most HEI I've worked with have ~20 deg. of mech. advance. With only 12 mech. the initial timing would have to be nearly 24 deg.
One other thing, take that Wells ignition module and throw it in the trash, their ignition products are junk. |
right- what Rhansen said. I don't want to start my initial at 24 degrees. this is a more or less stock motor w/performance intake bored over 30. There's nothing else done to it.
I'll take your advice on the wells. I'm positive those pins are preventing full advance - does anybody know the best way to get them out? |
it looks to me like that center plate is too wide causing the weights to stop too soon. look at the second picture compared to the first, and it looks much wider then the second.
i dunno... just my opinion.... |
Flip the center part of the advance plate upside down. I don't know how much advance it will gain you but it does look thinner on that side.
Tip: Keyboarding the correct "degrees" character
Ever wonder how to make the correct "°" symbol? I spent a LOT of time looking all over the keyboard for that Try holding down [Alt], and then type "0176" result: 12° mechanical. Just one of those trivial "had to know" things Don |
did that, and cut the posts off that were keeping it from rotating. then I put back the weights that were on it before I got the timing kit- much better feel to them and they look more like the ones in that rebuild pic.
Hopefully I didn't leave it off balance... might have a new distributor on the shopping list after all
Hopefully I didn't leave it off balance... might have a new distributor on the shopping list after all Don... thanks buddy but * is hellof easier to do than ... hey, it won't even work on my pc. Oh well...
solved
two things were happening- 1) the pins were preventing full rotation. Put the stock weights on, and still only had 12*. So I was playing with the advance and noticed 2)the weights were jamming in the oval hole the advance rides in. SO I put the spectre kit in, which uses a wider center weight, and voila- now I have my 20* mechanical.
Wish me luck that it will solve somehow my warm start one time stumble.
| Best Way to Install an HEI Ignition? | Smoked Rubber | Engine | 11 | 05-11-2005 03:33 PM |
| HEI help...before I go crazy | EricTopless68 Camaro | Engine | 13 | 09-29-2003 09:08 AM |
| HEI wiring diagram | oz_vette | Electrical | 2 | 08-13-2003 07:54 AM |
| Do I Need Little HEI Box for New HEI Dist? | Mr.56Chevy | Electrical | 0 | 12-23-2002 02:38 PM |
| Power to HEI | Seon | Electrical | 3 | 09-27-2002 03:03 PM |
