hei doesn't work when all wires connected - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-08-2008, 03:13 PM
Last journal entry: My 83 Chevy PU
I have an '83 Chevy 1500 with a 305 and automatic trans.
I just installed new head gaskets and now I can't get the thing to start. I suspect the HEI.
After I put the engine back together, the thing sounded like it was turning over slow. I had the battery and the starter checked and both passed. I did, however replace the battery.
The one thing I've noticed is this: If I disconnect the wire that goes in the 'bat' position at the coil, the engine turns over with vigor, but I get no spark (of course).
Also, If I disconnect the four prong connector that comes out the back of the distributor; the engine turns over quickly, but again no spark (and I don't expect any).
It seems like I have everything plugged in where it used to be and where it should be but something's not right and I'm beyond my skills. Any help would be greatly appreciated.
Thanks
Old 06-08-2008, 04:21 PM
T-bucket23's Avatar
Wiki Edits: 26
You timing is to far advanced or your wires are out of order. Try turning the distributor a little clockwise and see if it turns better and will start.
CHet
Old 06-08-2008, 06:02 PM
advanced timing
A few days ago I did find a couple wires out of sequence and fixed it.
I turned the cap a little clockwise after reading your post. I did seem like it found a place that cranked a little easier, but didn't fire.
It kind of sounds like WHOOOP WHOOOP WHOOOP.
A little more background: Before posting here I started taking things apart. I took all the belts off to make sure none of the accessories were hanging up.
After that I took the valve covers off to observe the lifters.
That's when I decided to check the distributor, and found the problem I'm having.
I guess I should've put that in my first post. I don't know if that makes any difference in the situation.
Old 06-16-2008, 10:14 PM
Fixed it
Just an update. I popped the covers off again, turned the crank til TDC on one and checked that the rotor was in the right place. Well, it wasn't.
Put a long screwdriver in and turned the oil pump - boom, it fired. A little fine tuning tomorrow.
Thanks for the help.
Tips for shop layouts and tool purchases. schnitz Garage - Tools 9 10-18-2010 11:19 PM
Part-time customizers need advice Dreadlord Garage - Tools 37 04-08-2009 04:58 PM
How much Work do you do? budthespud General Rodding Tech 31 01-03-2008 09:08 AM
heated wires and performance problems g.b. Engine 3 02-11-2006 09:16 AM
HEI Woes 79TTOPTA Electrical 2 06-07-2005 04:07 PM
