hei education - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-25-2005, 11:22 AM
nettio's Avatar
hei education
Actually wish to ask two questions:
1. Have one 350 with a mallory dual point distributor. It works OK but I really dont understand the configuration.
It has oiling pads between the points rub block and the distributor cam. How does this work?.........I am calling the felt type pad an "oiling pad.
Is this correct.
2. Wish to replace the Mallory distributor with a HEI. I find lots of them for sale on e-bay. Would like one that is one wire and has a tach drive outlet. and is not a computer motor unit.
What do I look for?
Thanks
Old 08-25-2005, 12:53 PM
larryblack's Avatar
Certified Lead Foot
Look for any 70's model HEI dist. They are basically 1 wire hookup.
You could get an blueprint one from accel. 1 wire hook up and it will drive a tach provided the tach is compatable with the HEI.
BTW, is the mallory a YC or YL code dist?
Old 08-25-2005, 12:59 PM
T-bucket23's Avatar
Wiki Edits: 26
Hei
Is this correct.
What do I look for?
Thanks
An HEI will drop right in 1 wire hook up. Im not sure about a mechanical tach drive. They do have a tach terminal that will drive an electronic tach. The Oiling pad on the old dual point is to lubricate the cam the the point rubbing block rides on to extend the life of the block. It requires special lubricant that usually comes with the points.
On installing the HEi it does require full battery voltage. A lot of the older cars had a resistor wire feeding the ignition circuit when the engine was running. This would have to be replace so you have a 12 volt supply. This usually fed off of the r terminal on the starter. this is usually the only modification that is needed to drop in an HEI
Old 08-27-2005, 12:53 AM
72donk's Avatar
New Member
yea it took me a while to catch on to that too, i think they jus run the red, purple, and black to the starter, big difference with hei in pointz car.
72 350 w/ HEI won't start roadbase Engine 3 07-14-2005 02:33 AM
New GM hei distributor quit. HELP fouroheight68 Engine 16 02-15-2005 07:30 PM
My HEI Won't Fit? Coodeville Electrical 1 07-22-2003 03:08 PM
Do I Need Little HEI Box for New HEI Dist? Mr.56Chevy Electrical 0 12-23-2002 03:38 PM
Power to HEI Seon Electrical 3 09-27-2002 04:03 PM
