hei in ford 351w - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-28-2011, 05:21 AM
hei in ford 351w
pls help
truck starts cold and runs, but runs a little rough.
once warmed up, and you turn off it will not start, almost like bad battery connection.
could the hei module cause this?
Old 05-29-2011, 12:11 AM
mud.man.rj's Avatar
The module will let it turn over but not fire because of no spark.
Old 05-29-2011, 12:13 AM
techinspector1's Avatar
Wiki Edits: 326
Install a whole new set of ground straps on it. Grind down to bare metal and tie motor to frame and frame to body.
Old 05-29-2011, 05:41 AM
Irelands child's Avatar
Tell us what the year of the truck/engine is as there are two types of ignitions - a separate module about 4x5 inches and mounted on the fenderwell. The other, is mounted on the distributor with 2 screws - this one needs dielectric grease between it and the distributor or some corrosion will form and run like you described. It may be heat failing as well. The other, fender well versions have histories, depending on brand of failing like you said - the fix: replace it
Dave W
Irelands child
Old 06-02-2011, 03:58 AM
1986 f150 with carburated 351w
previous owner installed a gm type hei.
i replaced the module, cap and rotor, and vacuum advance so far.
im going to look at plugs and wires next.
pings at highway speed when accelerating and still will not turn over when warmed up.
thank you for the feed back.
pas
Heads 351W Ford Eng. dmx6 Engine 32 11-30-2010 11:05 PM
Ford 460 vs 351W GranTorinoElite Engine 12 05-30-2007 09:31 AM
351w or 302? Ford gezzer Engine 6 02-12-2007 11:58 AM
Ford 351W McF Engine 3 03-05-2006 05:24 PM
Ford 351W denster Engine 2 06-18-2003 03:17 PM
