HEI Ignition Help
When detailing my Hot Rod for a Car Show, I removed my ignition wires (one-by-one) from their wiring harness/brackets and wiped them off with ArmorAll Protective Wipes. I thought I was being carefull to get the right wires back in the right places, but maybe not? When the work was done, I started the motor up and went for a drive. The motor started right up, but seemed to idle just a little rough (nothing major), but then when I backed off the gas, the car back-fired at low rpm's. Also, didn't seem to have the original horsepower? The motor is a Chevy Small Block 350 with a stock (Advance Auto Parts) HEI Ignition. I know the firing order on the block/cylinders, etc., but what about the distributor cap? Starring at the front of the block & distributor, which is #1,#2,#3,etc.? I looked for numbers, on the cap, but no luck? Could I have a couple wires crossed - in the wrong position? (I know the ones on the plug ends are in the correct position, they fit right back in their brackets as assembled. Anybody got a drawing of the firing order on the cap? Your help would be greatly appreciated. Thanks!
Doc here,
Your first mistake MAY have been putting Amoral on HEI plug wires..If they are even slightly broken down, they will crossfire like a bigdawg..... Second, The Fire Order is, for an SBC, 1, 8, 4, 3, 6, (And this is important) **-->5, 7,<--** 2...IF 7 and 5 Are reversed..It will display the performance issues you describe also. 5 and 7 are most common because they are the ONLY 2 wires next to each other at BOTH ends..So Triple CHECK!! Direction of rotation is Clockwise, and Traditionally #1 plug tower is located between 5 and 7 O'Clock..(although it could be anywhere predicated on clearance issues.) Facing the engine... The Driver's side bank: 1 3 5 7 The Passenger's Side Bank: 2 4 6 8 Doc
Aftermarket Solutions Electronic & Electrical Innovations |
HEI Ignition Help
Hi Doc,
Thanks for your help! You were right ... #5 & #7 were reversed. It wasn't the ArmorAll after all. The ignition wires are Taylor Brand and are like new, so I figured it was probably something else. (I forgot to mention, I Armor-All'd one side at a time, days apart. After doing the passenger side first, I had driven the car with no problems) Just in case though, I think next time I'll use WD40. Glad you "suggested" I Triple check my work. Thanks again! Grant p.s. - know anything about keeping chrome headers from bluing or tarnishing? (see my post & thread under General Hot Rod discussion) |
Doc here,
Doc
| Ignition system info................ | poncho62 | Electrical | 18 | 10-11-2008 10:10 PM |
| 1969 Camaro HEI ignition location Question | Izzy17ri | Engine | 1 | 12-08-2005 04:38 PM |
| Tachometer and HEI ignition | cool rockin daddy | Electrical | 1 | 09-08-2005 03:27 AM |
| Best Way to Install an HEI Ignition? | Smoked Rubber | Engine | 11 | 05-11-2005 03:33 PM |
| will pertronix fire stock hei ignition? | ted olmsted | Electrical | 1 | 08-24-2003 12:01 PM |
