HEI Ignition issues.
I've always used HEI's and never had any issue with them. However, dealing with one now that is in a restored 85 Corvette. The TPI and computer are still in use. It started out as it would run about 3 minutes then go dead and not start back. Spark test showed a really weak yellow spark.
Yanked it out, replaced the pickup coil, module, distributor cap and coil in cap. Reinstalled it, got it in time the car fired right up, ran about 3 seconds and went dead. Recheck spark, same thing, except this time it would spark every other revolution, again spark yellow and weak. Next was start swapping parts until one fixes it. Swapped modules, nothing. Swapped coils, nothing. Checked Voltage at hot wire, solid 12 volts. Checked the ground, looks good. The only thing left in the system is the spark control module, but I don't see why that would make it produce a really weak spark. It's been my experience in the past a weak spark was either the module or the coil. Checked the ohms on the pickup coil, they were in spec. Pickup coil has a strong magnitism to it. Stumped here, I dunno what else to check, any pointers would be appreciated.
