Hotrodders Bulletin Board
#1
hei ignition ques.
to start off, when i had my 231 in my malibu classic i could hook up a tack to the distributor but it wouldnt read anything. now that i have a 305 in its place still with the HEI ignition the tack still wont work will it? what do i have to do for the tack to work with the HEI?
#2
re: hei ignition ques.
Maybe the tach is bad, or missing other wires? There is only one wire on the HEI for the tach and it's marked, it's the one next to the "batt" terminal.
#3
yea, i hooked it up to that connector on my 231 and had no luck so i took it back. it was just a little cheap one anyways...ill try with a new one in a few weeks to see if it works
Back to top |
Similar Threads for: "hei ignition ques."
| Ignition system info................ | poncho62 | Electrical | 18 | 10-11-2008 10:10 PM |
| HEI ignition and 700r tranny | kycsomc | Introduce Yourself | 2 | 02-22-2008 01:13 PM |
| Tachometer and HEI ignition | cool rockin daddy | Electrical | 1 | 09-08-2005 03:27 AM |
| Best Way to Install an HEI Ignition? | Smoked Rubber | Engine | 11 | 05-11-2005 03:33 PM |
| will pertronix fire stock hei ignition? | ted olmsted | Electrical | 1 | 08-24-2003 12:01 PM |
