HEI ignition set up question - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-29-2005, 08:36 AM
I am trying to install a GM HEI distributor in my newly rebuilt 350, my question is, does the distributor body have a mark on it to tell me where the spark will fire?
Old 11-29-2005, 08:43 AM
Hei
Usually they don't. Install the cap and mark on the housing with a marker/paint stick where #1 will fire. When this is marked, usually the connections for the power/tach are facing the rear of the engine.
Chris Laarman
Ottawa Engine and Performance
www.ottawaengine.com
Old 11-29-2005, 08:45 AM
How do I determine where #1 will fire?
Old 11-29-2005, 09:55 AM
chianesi's Avatar
Never Give Up
Bring the number One piston to TDC, when inserting the dist. make sure the rotor button is lined up on the cap with number one and it points to the number one cylinder. One mine, the tach/batt terminals runs parallel to the firewall on the drivers side...
Old 11-29-2005, 10:04 AM
sbchevfreak's Avatar
Licenced Automotive Technician
Try looking in Hotrodding Basics . I'm fairly sure this issue has been addressed before, and you may findseveral other things that will help with your build.
HEI Ignition fatrat Electrical 5 08-02-2004 07:50 PM
69 Pontiac Firebird HEI Distributor Question pontiac69 Engine 13 12-01-2003 09:35 PM
What components are needed for a SBC HEI ignition? jpd37 Engine 10 12-01-2003 04:39 PM
will pertronix fire stock hei ignition? ted olmsted Electrical 1 08-24-2003 01:01 PM
HEI Ignition For 71 Vette 350 fpopper Electrical 1 05-07-2003 04:44 PM
