HEI Installition - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-09-2011, 03:13 PM
57halfton's Avatar
HEI Installition
Ahh , its been a while since i've done this , I am going to put an HEI dist. in my old Chevy pickup and take out an old points dist. I need to hook the battery terminal on the HEI to a keyed 12 volt source (on /off) , right ????
Can I use the wire to positive side of my old coil for the 12 volt source on the HEI ?
Gene
Old 02-09-2011, 03:26 PM
SSedan64's Avatar
http://rmcavoy.freeshell.org/HEI.html
http://www.oldengine.org/unfaq/hei.htm
I'm not sure when GM started using the Resistor Wire. If your truck has a Ceramic type Resistor you can eliminate it & use the + wire to Coil.
Old 02-09-2011, 03:33 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Gene
Gene, Have you thought about a petronix conversion kit then it will look like a stock distributor and wires when done. JMO Which distributor are you planning on going with ?
Cole
Old 02-09-2011, 06:10 PM
57halfton's Avatar
I have a GM HEI under my work bench and a wore out point distributor in my pickup sooooo I figured it was time swap.
Old 02-09-2011, 07:43 PM
SSedan64's Avatar
Sounds like the wise choice, also new HEI's are very cheap now. Many don't think about those ancient Points Distributor bearings/bushings being worn out when installing the Electronic conversion parts.
Old 02-09-2011, 08:00 PM
eloc431962's Avatar
Wiki Edits: 37
Yep if you already have a distributor that's definitely the way i would go.
Cole
Old 02-09-2011, 08:13 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If I'm not mistaken, this would have been '66, at least for Chevy.
Old 02-10-2011, 02:07 AM
SSedan64's Avatar
Thanks Mark, it's been a while since I've seen anything old that hasn't been converted.
Todd
Old 02-10-2011, 11:41 AM
57halfton's Avatar
My pickup has a 54 year old mess of wiring in it that will be replaced someday when I change cabs but for now everything still works. It has a ceramic resistor on the firewall with a green wire on the bottom that goes into the harness to the ignition switch and back out to the positive side of the old coil, I am thinking I can use that green wire to hookup to the battery terminal on the HEI distributor. Will that work ????
Old 02-10-2011, 11:46 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
My pickup has a 54 year old mess of wiring in it that will be replaced someday when I change cabs but for now everything still works. It has a ceramic resistor on the firewall with a green wire on the bottom that goes into the harness to the ignition switch and back out to the positive side of the old coil, I am thinking I can use that green wire to hookup to the battery terminal on the HEI distributor. Will that work????
It sure should, but check the voltage at the end of the wire (without the ballast resistor, obviously) to be sure the wire isn't a resistor wire. If you get full battery voltage , or very close to it (there will be some amount of voltage drop), that's your wire.
Old 02-11-2011, 07:13 PM
57halfton's Avatar
Well I got my HEI installed today and drove it around the block and everything seems ok, pings alittle so i'll play with the timing tomorrow.
Thanks for your help guys, Gene
Old 02-11-2011, 09:00 PM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
Good the hear its working for you.
If the HEI was old and had been of un known origin here is a link to check out the basics if you have not already done so.
http://www.rustynutscarclub.com/HEI.htm
TJ
Old 02-13-2011, 10:08 AM
ogre's Avatar
the 'Duracell Project'
halfton
i'm surprised it fit. most are those big things that don't fit under our firewall.
do you know what it came out of?
post what you did in DD's thread, i'm sure some of those guys would like to do the same thing.
Old 02-14-2011, 09:07 AM
57halfton's Avatar
When I took out the old six cylinder and put the V8 in it I mounted it about an inch farther forward than a stock V8 would have been. That gave me alittle more clearance between the valve covers and the firewall and for an HEI upgrade someday. Someday came last Saturday , glad I was thinking ahead.
Gene
