HEI issues - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-01-2010, 04:52 PM
HEI issues
I recently put a SBC 337 on the road. It ran for about 150miles and died with various issues. (minor teething problems) The one that bugs me is I have a 8364/5 MSD ignition module which I have run successfully for months, I decided to upgrade the coil to the recommended 8225, solid rotor button, Accel 25ohm wires. It started right up and drove fine for ~150miles and then died with no spark(I think). Is my selection of parts not appropriate for the street in terms of compatibility, longevity, or am I just unlucky?
I will swap in a stock coil, carbon button, stock module sequentially tomorrow and try and nail it down...it just picks me. You spend all kinds of time and money on fitment and decent parts and then something like this leaves you stranded on the side of the road (nothing a John Deere won't fix)
Old 07-01-2010, 05:33 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
On an HEI there are two small wires (green and off white) that run from the pick up coil to the two small terminals on the module (if a 4-pin module, that is). These will get broken inside of the insulation from years of movement caused by the vacuum advance working.
Also be sure you're still getting full battery voltage to the terminal at the coil cover.
Swap one thing at a time so you know which part is bad. I would start w/the module.
Good luck.
Locking Mech and vac advance on HEI issues maxpower_454 Engine 7 05-20-2010 05:46 PM
detonation issues and help with Mallory HEI darom Engine 13 05-08-2005 09:11 PM
pontiac HEI issues Jared Engine 4 04-17-2003 12:15 PM
Do I Need Little HEI Box for New HEI Dist? Mr.56Chevy Electrical 0 12-23-2002 02:38 PM
