HEI Modules - Page 2 - Hot Rod Forum : Hotrodders Bulletin Board
  #16 (permalink)
Old 03-19-2013, 04:40 AM
Banned
Originally Posted by ap72 View Post
The other thing is that there are many reboxed stock replacement offshore modules, which all suck, they fail early and they tend to put out a lot of signal noise, I went through 3 modules in a month before I went to a better brand. These were NOT performance modules though and I have never used a mallory one.
DUI modules seem to have a good reputation and I have never had problems with an ACDelco module, there's another brand I just started using as well that seems to be holding up fine but the name escapes me at the moment, its something like BRG but that's not it. Its 3 letters beginning with a B.
bwd (borg warner)
  #17 (permalink)
Old 03-19-2013, 10:50 AM
I was reading this thread and nodding my head with the fact that I too seem to be another victim of a poor quality off shore module.
Initially I was experiencing an engine miss under high load which prompted me to replace the plugs, wires, dist cap and rotor, also the external coil { its a 95 truck with the 350 TBI }. None of those items made any difference so I took it to my mechanic to check things out and from his experience he felt the original distributor was most likely at fault and replace it with a "new" one from a parts supplier. Yes, that did solve the miss under load so I can only assume ether the old module or the distributor possibly becoming magnetized could have been the cause. So I thought all should be good now but no, a week later the engine would start and quit a few times before it would stay running, also quit randomly when coming to a stop and not on the throttle or buck and jerk the driveline violently out of the blue when at lower rpm but high load. Long story short, the module kicked out a code so the engine check light was on and it was tested at a shop and they said the body of the module was not grounding because of an internal failure. I replaced it myself with a GM Delco unit and that part of the dist has been good since. I did note that the prongs were physically smaller in diameter on the aftermarket module compared to the GM one which in my mind told me it was manufactured as cheaply as possible. Now I am having the gear on this same unit wearing at a high rate after replacing the cam shaft and I called the rep for the company that supplies this brand of new or reman parts and he said right off ... these distributors even though they are brand new, are junk !. My jaw fell open for the simple reason, how often do you hear the rep for a supplier of parts just out and out tell a customer that sadly they are handling a totally inferior product. I was going to replace the gear with a genuine GM unit but then come to find the shaft size is unique to the offshore unit so .... I ordered a brand new GM Delco distributor and the parts supplier will take this one back !. What a gong show and the insane amount of shop $$$ to figure out its due to poor quality parts.
So StudebakerTom, beware the offshore pitfalls of "will fit parts" and if you need to replace a cap/coil or module, choose one that these gentlemen are suggesting rather then be tempted by a lower price.
  #18 (permalink)
Old 03-19-2013, 11:12 AM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
There are so many options,,, this is one that makes sense. Over seas module? dont know, dont care. Mine has 15 ooo miles on it and never missed a beat. I know of few more of these, not one problem, try and beat the value.
White Performance Detail Description
MSD modules Overdriv General Rodding Tech 1 10-10-2009 01:44 PM
performance modules wyotech22 Engine 2 11-08-2008 05:47 PM
Eating ignition modules rorton Engine 8 01-14-2008 04:56 AM
Burning up HEI modules Kobwo Electrical 4 10-19-2003 11:27 AM
Burning up HEI modules Kobwo Engine 11 10-17-2003 10:04 AM
