HEI point gap - Hot Rod Forum : Hotrodders Bulletin Board
Old 09-06-2005, 12:12 PM
HEI spark plug gap
Should the spark plug gap change from .035" when swapping a stock (points) distributor to an HEI? This is a 67 chevy 283.
Old 09-06-2005, 12:43 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
HEI should be .045
Old 09-08-2005, 03:41 AM
docvette's Avatar
Wiki Edits: 12
Hei
doc here ,
$0 to 45 ... IN ADDITION to that should charge the wires to 8 or 8.5 m spiral core wires..to prevent Cross fires..an RF fields that will / can burn up the ECM.
The stock ones won't do the job..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
setting points on sb chevy frackster66 Electrical 23 01-07-2014 05:50 PM
"Basics of Basics" Sectioning a Body MARTINSR Body - Exterior 7 11-24-2008 12:04 PM
Ring End Gap bpd411 Engine 3 02-26-2003 09:19 AM
Do I Need Little HEI Box for New HEI Dist? Mr.56Chevy Electrical 0 12-23-2002 02:38 PM
Replacing a dual point with an OEM HEI HotRodF100 Engine 1 03-04-2002 04:30 PM
