HEI problem - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-16-2011, 02:44 PM
HEI problem
I have a small block Chevy with the HEI. About once a month I have to remove my distributor cap and wipe some oil or carbon off of the rotor clip and the *** from the coil. What is causing this?
Thanks
Old 11-16-2011, 03:17 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
This sounds like it could be a crankcase ventilation/blowby problem, JMO are you running a pcv valve ? and how many miles is on the engine /
Oh and welcome to the site. also just how old is the distributer anyway ?
Cole
Old 11-17-2011, 02:20 PM
I do have a PCV valve, the motor has about 40,000 miles on it and it was a new crate motor and a new HEI distributor about 10 years ago. It is in a 51 Ford Pickup that I cruise around in on the weekends. This problem has been around for at least the last 20,000 miles. I have changed the distributor cap and rotor just recently. I changed the plugs, wires, distributor cap and rotor all once a while ago. I changed the PCV value just recently also.
Heater problem turn to engine problem Ridertj Electrical 1 10-29-2011 11:18 AM
timming problem?? or carb problem???? helppp 85 k5 mud truck Engine 10 06-05-2009 04:59 PM
having a wiper problem in my chevy truck, and a taillight fashing problem in my GMC ChevyJim Electrical 5 01-28-2006 07:20 AM
95 Camaro fan switch problem / ignition key problem human_forklift Electrical 7 10-24-2004 11:37 AM
starter problem ? timing problem? 6speedwagon Engine 1 08-11-2004 11:37 AM
