hei problems - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-15-2012, 07:04 PM
hei problems
I have a 63 chevy c 10 pick up with a fairly new gm 350 crate motor. Recently the truck died on the freeway with no warning. Would not restart. I removed the distributor cap only and reinstalled. Truck started right up. This has happened about 5 times in the last week. The truck has also been having intermittent problems with it wanting to die when I stop really fast. As if fuel floats are not set right. Then out of the blue it runs fine again, except for the engine just quitting. I checked the ignition switch and it is fine. Seems to me that it is def HEI related. Does it sound like the module? Any help would be appreciated
Old 06-15-2012, 07:05 PM
The fuel pump and fuel pressure are good also.
Old 06-15-2012, 07:22 PM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
With the cap removal fixing it I would suggest checking the wiring under the coil cover, take the cover off and check the coil wiring and stake on type connectors that accept the power plug end if so equipped
Check for engine proper ground
Ensure that the HEI gets constant 12VDC+
Yes the module can heat up and get flaky causing intermittent operation
The coil itself can be weak
If you have another HEI cap and coil install it and see what gives.
Old 06-15-2012, 08:30 PM
cool rockin daddy's Avatar
That little carbon button under cap might be out of place or the washer under it is bad. Carbon tracking near it can cause misfires. Check it also.
Old 06-15-2012, 09:47 PM
Years ago I had a small Hemi in a model A. I had a similar problem. When the dist advanced it pulled a wire to ground, and the engine quit. It was a points setup, but I suggest you look at the distributor internal wiring and make sure nothing is hooking it, or nothing is rotating causing wires to contact ground. The way HEI advance works, I doubt this is your problem, but if something in the distributor is amuck in this way, it'd sure be a cheap and easy fix.
PatM
Old 06-15-2012, 09:50 PM
Banned User
What is the age of the distributor? It could also be the wires (green and white?) on the pickup. They sometimes go bad from all the movement?
Old 06-16-2012, 02:17 AM
ronbuhg's Avatar
all of the above answers are good, my experience has usually turned out to be a bad module caused by what they used to call 'heat soak',working fine when cool, quitting when hot. hey guys which rotor was it that used to burn through quicker ?the white or black one.cant remember, I 'think' it was black ?also quitting when doing a panic stop,up your idle speed slighty,sounds like its too low, 50-100 rpms maybe should fix that,if floats are off you would have problems all over the place,not just when stopping
Old 06-16-2012, 11:17 AM
Changing out the module today. Bought one of those ignition tune up kits from pro form. The coil seems a bit weak also. Going to do a complete ignition tune up. Thanks for all the replies.
Old 06-16-2012, 03:26 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Use heat sink compound from Radio Shack or a computer repair store to put under the module. That compound allows heat to pass from the module into the distributor body. One type is shown here.
Old 06-16-2012, 03:45 PM
T-bucket23's Avatar
Wiki Edits: 26
Do your self a favor, send back the pro form crap and get some AC Delco parts.
As to your original issue. I would check the connections on the outside of the cap. It could just be when you remove and reinstall the cap you are moving the connections enough for them to make again. Also take the rotor off and see if it is burnt through in the middle.
Chet
HEI Distributor problems usa3990 Electrical 3 09-16-2010 04:42 PM
HEI and Manifold fitment problems BowTiePride Engine 12 03-04-2010 03:33 PM
stock HEI to Small body HEI now there's problems, need help Doc fat50chevy Electrical 6 07-13-2006 04:19 PM
HEI problems--- help blownalkybbc Electrical 8 07-01-2006 10:23 PM
HEI problems Marcus Electrical 6 12-29-2002 08:22 PM
