hei question - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-28-2009, 06:40 PM
72 grabber 51F-1 65 chevystang
hei question
I was wondering how how wired up a factory gm hei distributor. I have heard they just need a hot wire but I am not sure. I would prefer to run this over a points distributor
Old 11-28-2009, 06:47 PM
TroyBoy's Avatar
Psychomotors
On my 70 Nova and the couple old trucks I've had,I ran an 8 gauge wire to the pink hot wire on the ign switch.If you're wiring this in a Ford, I don't know which one is your hot wire and you will have to look in a service manual or use a tester.You will only have 12v when the car is running and no probs
Old 11-28-2009, 07:44 PM
All I know is get rid of any resistor wire that may have gone to your coil.
Next, an un-fused ignition switched B+ wire goes to the BAT terminal on the HEI distributor.
You may have to splice in an additional wire to the B+ distributor terminal that is hot during cranking (a wire from the resistor terminal on your remote solenoid), if your main ignition switch doesn't do that for you. My old '57 chevy had this issue. It had IGN1 and IGN2 switch terminals.
Sometimes there is a "feedback" problem that prevents the engine from stopping because current from the alternator has a path back to the ignition switch.
If you have a little generator idiot lamp in the circuit, you are spared this aggravation. If not, you may need to install a diode (#276-1661) from rat shack. Solder it in series anywhere between the alternator's #1 terminal and it's termination at your ignition switch (IGN1). Orient the painted stripe on the diode toward the alternator's side of the circuit.
If you have an IGN2 terminal on your ignition switch, I also install another diode somewhere between the switch's IGN2 terminal and it's termination at the IGN1 splice at the distributor.
Some people just solder a diode between the IGN1 and IGN2 terminals at the ignition switch (solder the diode with it's stripe closest to the IGN1 terminal). Then you can forget all about having an IGN2 terminal on your ignition switch.
Mark Hamilton at madelectrical.com has kits and excellent explanations for all these issues.
Old 12-01-2009, 04:59 PM
fast68's Avatar
likes chevy trucks & boobies
one hot wire is all to ign unfused use an inline fuse
easy simple done cake walk
dont use the original small cloth wrapped wire anymore, and the yellow wire from starter to coil do away with this also
Old 12-01-2009, 06:04 PM
302 Z28's Avatar
Be sure you are not using the original resistance wire. You need a properly sized copper wire to that HEI unit.
Vince
Gm HEI distributor question jody chevelle Electrical 5 04-15-2007 05:32 PM
Quick question on HEI coils. Jmark Engine 7 11-02-2004 09:11 PM
69 Pontiac Firebird HEI Distributor Question pontiac69 Engine 13 12-01-2003 08:35 PM
Hi All I just Joined, Questions Re:454 rebuild Gay-Shark Engine 8 11-29-2003 10:25 AM
GM HEI Distributor question Jag Daddy Engine 8 10-30-2003 05:12 PM
