HEI shaft bushings - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-12-2012, 06:29 PM
HEI shaft bushings
I have a bad upper shaft bushing in my delco HEI ditributor, and I cannot find a replacement. Does anyone know where I can order one?
Old 01-12-2012, 07:28 PM
Custom10's Avatar
my KARMA ran over my DOGMA
Last journal entry: SS
I would take a real close look at the shaft if the bushing is worn out. May consider new dist if you can loose the vintage OEM. Give these guys a call and see if the vette dist bushing is the same as the one you have, they sell the tool as well for remove/install. However you can buy a new HEI for 55 bucks form another vendor skip white:
http://www.mamotorworks.com/corvette?frame=1.1171
Old 01-13-2012, 01:38 PM
crazypj's Avatar
I fake being smart
You could take a look at McMaster Carr for oilite bushings.
Find a hobby machinist to modify them as it's a real simple job
Old 01-14-2012, 03:00 AM
DoubleVision's Avatar
A GM parts counter at a dealership is your best bet as they are the only ones I know that used to carry them, I don't know if they still do.
Old 01-14-2012, 09:32 AM
Thanks
Thanks for all the info, those Skip White prices look really good, that web site went strait to favorites. My buddy Rick gave me a housing with good bushings so all is well!
speed demon - throttle shaft bushings or bearings? 60smotorhead Engine 3 07-26-2009 02:30 PM
throttle shaft bushings mhamilton Engine 3 03-25-2006 05:51 PM
Life just went to HeII! HemmiGremmie Hotrodders' Lounge 7 11-18-2004 07:34 AM
Holley throttle shaft bushings hemiford Engine 7 02-14-2004 08:02 PM
Whare to buy Holley throttle shaft bushings? newchevyman Engine 2 09-01-2003 11:07 AM
