HEI springs - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-12-2006, 02:49 PM
HEI springs
Does anyone know where I can get stock replacement springs for the HEI mechanical advance? Mine is coming in much too early and too fast, just slightly above idle it starts moving with the vac disconnected. This is for a stock engine, so I was hoping to stay away from the recurve spring kits.
Local auto parts stores have the weight bushings, but no springs.
Thanks,
-Michael
Old 01-12-2006, 03:57 PM
get the kit from summit or jegs, the kit will come with soft to hard springs so you can custom taylor your setup. also it will come with weight to replace them too if you want to.
Old 01-12-2006, 04:57 PM
I was looking at the Summit kit (springs, weights, bushings, and plate), do you know if either set of those springs comes close to the original stiffness? I guess for $5 it's worth a gamble...
Old 01-12-2006, 09:29 PM
Jmark's Avatar
Most Checker/Schucks/Kragen auto parts carry the recurve kits too. They have an assortmant of springs in them. Might save a mail order wait.
Mark
Old 01-13-2006, 03:25 PM
adryan16's Avatar
Engine Builder Mentee
I would reccomend O'Reiley's or the sort first. Saves you shipping and the wait. I've put three or four of the inexpensive Mr. Gasket kits in my different distributors, and with all the combinations of springs, there's a lot that you can do to tune on it. Good luck.
Old 01-13-2006, 03:48 PM
curtis73's Avatar
Hates: Liver. Loves: Diesel
Wiki Edits: 16
How about a junkyard? Find a similar application from a similar year and snag the springs (or the whole HEI) from it.
It might be a bit trial and error. There are no cut and dried rules when it comes to HEI curve springs. Over the years weights and springs were farmed out to the lowest bidder and they changed more often than the weather in Chicago. Those spring kits come with their own weights since they can't predict what weights are on your HEI. That's why I maybe suggest getting an HEI from a vehicle that was a similar application. For the most part all of GMs low-po HEIs gave all their advance by 3000 rpms or a little more. The problem is; did they do it with light springs and light weights, or heavy weights/springs? Just snagging the springs might not get you exactly what you need.
Also (just to throw more confusion in the mix) the aftermarket kits are terribly inaccurate. I bought the Accel kit for my HEI and installed their weights and the 3000 rpm springs. On the Sun tester, they had all of their advance in by 900 distributor RPMs or 1800 crank RPMs. That's WAAAY off. I purchased a Mallory kit and they had a 2800 combo that actually gave all of its advance by 2000 on the crank. In the end since I had access to the Sun tester, I just dug through the parts bin and found several matched springs that "looked" right and tried them until I got the right curve.
Old 01-13-2006, 04:18 PM
Thanks for all the suggestions. I've gone ahead and ordered the kit from Summit. I don't have any O'Reillys or that chain around here. Just Advanced Auto and Napa. Junkyards around here just have late model imports.
Looking at their catalog and reading the PDF instructions for the kit, I think I can find something that works. Right now my mechanical advance is coming in almost fully right above idle. I've got the factory specs on the curve, so I hope I can get it to match close enough with a stiffer spring.
Old 01-13-2006, 08:31 PM
Don't know what you consider low performance, but the GM specs for my '76 'vette L-48, show max centrifugal advance of 22* at between 4200 and 4600 rpm, depending upon auto or manual transmission. The Hi Po L-82 shows a max advance of 16* at 2000 rpm.
Consequences of wrong springs on my heads? TVR383 Engine 6 11-23-2005 10:25 PM
Diffrent Springs? strikingthematch Engine 3 12-09-2004 09:12 PM
HEI Springs Sweet-34 Hotrodding Basics 5 04-14-2004 11:46 PM
Valve Springs GearHead69 Engine 5 07-19-2003 11:00 AM
Do I Need Little HEI Box for New HEI Dist? Mr.56Chevy Electrical 0 12-23-2002 02:38 PM
