HEI suoer coil 140003 - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-29-2012, 10:39 PM
I have a Chevy 350 in a 1980 C10 SWB truck i have installed a Jegs P/N 249-12-600-4
Thumpr Hydraulic Flat Tappet Cam
Adv/Dur: 279/297
RPM Range: 2000 to 5800
Intake/Exhaust Lift: .479/.465
with a Edelbrock 7101 - Edelbrock Performer RPM Manifold
and i had a friend that wanted me to install a Accel super coil 140003 w/Distributor so i did b ut now I was have problem
1st he told me to change spark plugs and gap the at .35 so i did and all was goods then one day i was driving home and it kept trying stalling then the next weekend i started the truck and when it got to running temp it would stall again i would restart and run about three min then stall gain so i replaced the ignition module it was running fine i was able to check water temp and any vacuum leaks after changing the manifold. so i changed the header gasket and a valve gasket then i put all the spark plug wires back and now it wont start. I have checked timing 1-8-4-3-6-5-7-2 i also bought another super coil and nothing it turns over like it wants to start like its starving for fuel but i see that its not. the distributor is stock and what i change the ignition mod was also stock should i up grade and get a mallory 607?
HEI coil voltage sqzbox General Rodding Tech 4 10-16-2013 10:02 AM
wiring hei with no coil atcoed Electrical 2 02-05-2012 08:13 AM
HEI coil help elcaminodragster Engine 13 10-01-2007 10:55 PM
HEI Coil adryan16 Electrical 3 03-16-2004 09:39 PM
HEI keeps blowing coil ???? WheresThisGo Engine 12 02-26-2004 12:35 AM
