HEI tach pulses - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-26-2005, 12:23 PM
vicrod's Avatar
life is a ride
Last journal entry: LED tail lights
HEI tach pulses
I'm trying to calibrate my VDO tachometer. The tach works but I don't trust the reading because it does not represent the correct RPM for gears I,m running.
I believe the pulse rate for the GM HEI distributor (engine is GMPP ZZ4) is (4) pulses per Rev. Should I be using a different pulse rate or do I need another calibrated tach to set this up?
Thanks for help.
Vicrod
Old 11-26-2005, 01:39 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
First check the calibration with a KNOWN Shop tach..Lay it over the hood and window and do a short test drive and note differences throughout the Gear range..
If you are comparing it to an old STOCK tach, Be sure you are AHEAD of the STOCK tach filter (If provided) to get accurate readings. This will be on the HEI White wire and resemble a "Noise Cap" usually mounted on the manifold.This will screw up your calibration by at least 1/2 after 1500 RPM's on an aftermarket Tach, and if you have both, don't defeat the stock tach, or your wipe the Amplifier card out.
I Should think the pulse rate would be divide by 8 per revolution, on an aftermarket tach, however divide by 2 is plausible (4 per revolution) Never really thought about it..Next time I bring the spectrum analyzer out, I'll make a point to check..I should think it would be divide by 8 though, as it mimics the output side of the coil...Is The Cyl Switch set correctly on the Tach?
If that's the case, you may need an adapter card for the Tach. Contact VDO for specs.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Sun Tach 383vette Electrical 6 12-30-2011 02:21 PM
HEI and factory tach Impalatom Electrical 3 06-26-2005 09:00 PM
mustang tach wiring stang_steve Electrical 0 07-14-2004 07:28 PM
HEI Tach Connection Sweet-34 Electrical 1 04-13-2004 03:40 PM
HEI w/ mech. tach drive for 71 big block vette 71 vette Electrical 2 09-30-2002 03:31 AM
