Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Hei top bushing
Thread: Hei top bushing
Old 09-24-2012, 07:41 AM
RWENUTS's Avatar
RWENUTS RWENUTS is offline
Perhaps nothing wrong with the top bushing! Centre Shaft could be moving up and down. You might need to shim it. Pull the gear off the bottom and put shims in between the gear and the housing to limit the upward movement.
