HEI Troble - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-18-2005, 03:15 PM
HEI Troble
My d***b a** brother removed the did. cap removed the wires and now know what color wire goes where and I have a book but it don't say a thing about what color wire goes where?
39 OLDROD
Old 07-18-2005, 05:06 PM
interro1's Avatar
Until death does it backfire!!
I'm a rookie...but maybe a description or a pic or some type of identifying data for the cap...maybe just the engine make and size would do?
I can assure you that there will be people on here that will answer your ? very quickly after you provide that info.
Old 07-18-2005, 05:09 PM
Rob Keller's Avatar
AKA:"SLOWRIDE66"take it easy!
Wiki Edits: 38
typical HEI dist has 5 lugs the 3 closest to the rotor is a plug that comes from the dist. to the cap then there is the power and tach and should be marked so on top of the cap if i'm reading you thread corectly.
hope this helps
sr66
"SlowRide66"
"Illegitimis non carborundum"
Old 07-18-2005, 05:33 PM
Thanks I got a few min. to check behind lil bro and found he wired the bliping thing back a**ed go figuer?
thank 39 OLDROD
HEI Distributor for Chevy 216? fastback49 Electrical 2 06-05-2005 03:00 PM
HEI help...before I go crazy EricTopless68 Camaro Engine 13 09-29-2003 10:08 AM
HEI wiring diagram oz_vette Electrical 2 08-13-2003 08:54 AM
Do I Need Little HEI Box for New HEI Dist? Mr.56Chevy Electrical 0 12-23-2002 03:38 PM
Power to HEI Seon Electrical 3 09-27-2002 04:03 PM
