HEI trouble - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-10-2005, 06:24 PM
New Member
HEI trouble
I have HEI Ing in my street rod had it running afew weeks bach went to start it and the engine turns over but will not fire ihave gas
Old 04-10-2005, 07:22 PM
poncho62's Avatar
Wiki Edits: 5
Check your wiring......see if you have 12 volts to the cap/coil...
Old 04-10-2005, 07:37 PM
New Member
HEI trouble
Yes i have 12 volts at dis. How do i troubleshoute the coil and mogule. Is there a way to test these items
Old 04-10-2005, 10:17 PM
bracketeer's Avatar
489 Lemans
Last journal entry: Street Legal
detailed instructions
Detailed instructions on checking points, module, regular coil, and hei coil are found here.
Old 04-11-2005, 06:07 AM
docvette's Avatar
Wiki Edits: 12
module
Doc here,
To test the module, simply pull it and take it to your nearest auto parts superstore, They will usually test it for free..
have them do it several times to "Heat " it up before they call it good...and If you need to get a new one have it tested too before you leave the store!
about 1 in 5 are bad out of the box.
Don't forget lots of heat sink compound when you put it or a new one back in or it will burn up.
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Hei trouble 46Studie Electrical 17 08-16-2003 07:38 AM
HEI trouble RodneyUSAF Engine 1 03-08-2003 06:06 PM
Do I Need Little HEI Box for New HEI Dist? Mr.56Chevy Electrical 0 12-23-2002 03:38 PM
Hei Distributor trouble jeff germano Engine 4 12-02-2002 10:06 AM
Power to HEI Seon Electrical 3 09-27-2002 04:03 PM
