Artificial Intelligence is no match for Natural Stupidity Chet |
Agreed, however, there is no short and wiring issues as I have already went through that very carefully. When I disconnected the tach from the dizzy issues gone. Like I said before, when I would touch the brakes causing a change in vacuum it would clear for a moment. This is a weird one for sure... |
If you are completely certain that the problem is not the tach wire, then the only other connection between the brake pedal and the distributor would be the brake light switch. Applying the brakes causes a slight voltage drop, if the installation of the HEI is marginal from a wiring standpoint or if there's a grounding issue with the tach, then the voltage drop MIGHT be related.
I know all that sounds likely but I really have checked all the wiring between the tach and the dizzy as well as anything thing that the brake pedal would interfere with. That is why this is so crazy. I WILL get to the bottom of this soon. With Easter last weekend I did not get a chance to disappear in the garage. I will take a look at the brake light circuit too which I had not done yet. Thanks guys for your input... ~m |
I was thinking this morning that this could very well be a bad coil in the HEI. Maybe the hookup of the tach wire is enough to kill it. The symptom is that of a bad coil, but the brake pedal thing is still somewhat of a mystery to me. Thoughts anyone...
~Mike |
| vacuum issue or carb issue idk for sure | chevyok06 | Engine | 1 | 07-10-2011 05:19 PM |
| will this tach work with HEI? | GMR | Electrical | 1 | 08-14-2008 03:03 PM |
| HEI tach pulses | vicrod | Electrical | 1 | 11-26-2005 01:39 PM |
| HEI and factory tach | Impalatom | Electrical | 3 | 06-26-2005 09:00 PM |
| HEI Tach Connection | Sweet-34 | Electrical | 1 | 04-13-2004 03:40 PM |
