Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - HEI Wiring Please help
Old 10-16-2004, 03:49 PM
docvette's Avatar
docvette docvette is offline
Wiki Edits: 12
wiring
Doc here
Unless the coil requires a resistor (and I think most after~market HEI's with external coil DO NOT) Your wiring will be the same as your stocker HEI.
Does the new one Have a "BRAINBOX" or is it all contained within the distributor?
Should Be A "plug and pray " Swap out!
Check to be sure your plug wires will handle the new high tension spark, and your plugs are gaped accordingly. and you should be gold!
Doc
