You have the wires correct.
Make sure when you hook up that power wire that you are hooked to a full 12 volts. If you are switching from a points ignition than the power wire you disconnected was only 9volts as they are ran through a resistor wire. By pass the resistor wire and cut into a SWITCHED 12 volt wire under the dash. You will be good to go!!!! |
