Heidts Front Crossmember in 1940 Chevy - Hot Rod Forum : Hotrodders Bulletin Board
Old 10-07-2005, 07:16 AM
Any tips on replacing
Old 10-07-2005, 05:06 PM
Wiki Edits: 49
Your question is incomplete. Are you talking about replacing the stock suspension with a Heidts unit or replacing and existing Heidts unit with something else?
Old 10-07-2005, 08:56 PM
sorry about incomplete info
Iam replaceing a stock mustang11 crossmember with heidts. The reasons are:
One the crossemember installation was butchered up. Two it was installed at a 5 degree angle down in the front.
Old 10-07-2005, 09:34 PM
Wiki Edits: 49
I can see why you would want to replace what you've got now.
The only advise I can offer is to cut out the existing crossmember as carefully as possible and then just follow the instructions on the Heidts unit for installation. Their units are easy to install, I've done one on a 41 Chevy coupe and a 53 pickup and once the frame is cleaned and ready for installation an experienced welder can install one in an afternoon.
Good luck.
1940 Chevy Coupe fastco Body - Exterior 6 01-10-2006 07:33 AM
1940 Chevy Coupe mecjac Hotrodding Basics 4 12-10-2004 06:52 AM
1954 chevy pickup tilt front end teach Introduce Yourself 5 11-30-2004 05:03 PM
bolt-on front crossmember jayjones Suspension - Brakes - Steering 2 06-21-2004 06:44 PM
front seat for 56 chevy iron56 Interior 2 01-15-2003 10:24 AM
