heidts with metric calipers and chevelle 11" rotors - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-21-2011, 10:06 AM
what do i need to change to 4 piston calipers ?
i have also seen the metric calipers that are over sized to 2 3/4"dia pistons.
what have you guys done to improve this setup ?
thanks , roger
Old 08-21-2011, 01:49 PM
Irelands child's Avatar
Roger - Why not take "journey" through the Wilwood catalog. That Heidt's suspension/front end probably wont limit anything as long as you use a complete kit for your spindle. Then of course, there are also metric two piston replacements from Wilwood ( FORGED BILLET D154 GM METRIC OE MOUNT REPLACEMENT CALIPER ).
From my experience installing discs on a '57-'59 Ford rear end - there was no listing by anyone else - but Wilwood does have the separate hardware to install their later 9" small bearing housing kit.
Here's the catalog - it's pretty big and a .pdf file See page 39 for a metric replacement caliper.
Dave W
Old 08-21-2011, 03:36 PM
ok, ill check those wilwoods out, thanks.
Old 08-21-2011, 05:13 PM
dave, i wonder if the wilwood 2 piston caliper would be better than the ones i have ? (gm metrics) i dont know what dia. piston they have .
roger
Old 08-22-2011, 05:23 AM
Roger - I sure do like the stainless pistons and the fact that the calipers themselves don't become a rusty blob. I have to say that the Wilwoods on all four corners of my '31 are very nice the way they stop the car and really do believe that the metric replacements will be a good addition. Pricing is not too bad - latest Wilwood price sheet
Dave W
PS: No I don't work for Wilwood Just like their products
on a ford 9 in rear end what rotors and calipers to use for disc brakes. 1931 graham rod Suspension - Brakes - Steering 2 10-31-2010 01:40 PM
Painting or coating calipers, rotors, coil springs, and sway bars??? zbhover Body - Exterior 7 04-10-2010 10:26 PM
GM metric rear calipers w/e-brake bentwings Suspension - Brakes - Steering 2 03-31-2009 08:16 AM
Need Calipers for 8.8 rotors 2000jack Suspension - Brakes - Steering 4 03-26-2008 09:20 AM
Wanting to use GM rotors and calipers on Mustang II spindles IRELAND EXHAUST Suspension - Brakes - Steering 1 04-19-2007 07:07 PM
