Heidt's X member install - Hot Rod Forum : Hotrodders Bulletin Board
Old 05-08-2007, 10:45 AM
I am preparing to install a Heidts X member in my 53 GMC 1/ ton. In the Heidt's kit, there are C notch that are included in the kit. Do these have to be installed or does the rack not have enough clearance? Anybody out there have experience with this?
Any advise is appreciated.
Old 05-08-2007, 01:41 PM
AllSteel34's Avatar
I installed another brand of MII front on my '49 and it did not require the bottom of the frame to be notched. I don't know about the Heidt's unit specifically.
Chris
Old 05-08-2007, 01:49 PM
What brand did you use? I have seen other brand x members that do not have to used the notches, but I guess it all depends on the distance betwwen the rack to the bottom of the frame.
I wonder if the Heidts x member is designed to be lower than most other types.....
Tom
Old 05-08-2007, 01:55 PM
oops ..duplicate post (sorry!)
Old 05-08-2007, 02:16 PM
stea's Avatar
Used the Heidts on my 39 GMC, I had to use the notches for clearance. Mine sits pretty low, don't know if this is a Heidts specific issue.
Old 05-08-2007, 05:26 PM
home brew's Avatar
Last wiki edit: Body and exterior tips Last photo:
6bolt - just for your information you are purchasing a front cross member not an X member. An X member is used to strengthen the frame and is located between the front cross member and the rear crossmember. See the pic below.
Name:	nice rear mnt. 2.jpg
Old 05-08-2007, 06:35 PM
powerrodsmike's Avatar
Wiki Edits: 161
Some have more drop than others. Some the drop is built in the spindle, some is in the crossmember
I put a Heidts MII in a 57 chevy pickup and it needed the c notches installed to clear the rack.
Later, mikey
BE different....ACT normal.
Old 05-08-2007, 06:37 PM
Wiki Edits: 49
Whether the "C" notch is required depends on the particular vehicle the kit is designed for. I used a Heidts unit on my '41 Chevy pro-street car and no notch was required. However, on my Chevy PU the "C" notch is required for the Mustang II rack to mount properly to the crossmember.
Here is a pic of the Heidts install on my '53 3100.
As you can see the "C" notch lines up with the mounting brackets on the crossmember, don't leave them out.
Here you can see (with everything bolted on) why the "C" notches are necessary.
k member or x member? Marty S. Hotrodding Basics 5 12-14-2006 11:46 PM
How to install a chimney for a wood heater rusttorod Garage - Tools 31 11-06-2006 08:56 PM
Spindle interchanges bskaggs Suspension - Brakes - Steering 11 06-05-2006 01:29 PM
Review of FatMan IFS Airbag install 1938 Chevy PU Grashopr Suspension - Brakes - Steering 3 08-25-2003 11:16 PM
member or jr. member??? WoodsEdge Hotrodders' Lounge 10 05-23-2002 06:30 PM
