Heim End/ ball joint - Hot Rod Forum : Hotrodders Bulletin Board
Old 01-31-2006, 02:50 PM
Hello
I am building a street/strip car and I was thinking of using custom spindles which I already have
The thing I was wondering is, if anyone is aware of a Heim end type that can be used for a ball joint. A regular Heim end sideways, I think would come apart and is not designed for this load
I need to find something that can thread into the spindle. , so I can bolt something down to it
take care
Tom
drag cars have something like this on strut front ends, but I don't know if it would be strong enough for a street car
Old 01-31-2006, 04:38 PM
woodz428's Avatar
Troll Hunter
There are several heim ends available to work. I have 2 Superformance Cobras ( A Coupe and a Roadster) and they both use heim joints for the balljoint application as do many of the Kit Car companies.
Old 02-01-2006, 07:07 PM
Using a "Heim" (should be called a spherical rod end) as a ball joint is a bad idea. It will put the threads of the shank in bending...which is the worst way to load threads.
Use a spherical bearing (aka uniball or monoball) with a cup. A quick google search will turn up many suppliers.
Old 02-06-2006, 04:28 PM
spherical bearing
Hello
I had tried to contact a couple of manufacturers of spherical bearings for this , but I have not heard back
I will try to see if I can find out anymore on this. I said heim end, but I should of said spherical bearing in my first post
A rod end would not work for me
take care
Tom
Old 02-06-2006, 05:51 PM
I have only used Aurora but I have heard that FK is a good brand too. Aurora has some very good info in their catalog (on their website).
www.aurorabearing.com
I used the AWC-TG series staked into the ends of the A-arms. As you most likely won't be staking them you can leave off the G on the end.
You could also look at the *IB-T series...
Whoever you get them from you want the wide series (if it will have an axial load) and for sure the PTFE (Teflon) lining.
Old 02-06-2006, 06:01 PM
To give you an idea on prices...
http://www.polyperformance.com/shop/...cat=106&page=1
http://www.mckenzies.com/catalog/sho...0047&cid=&id=0
http://www.mckenzies.com/catalog/sho...7351&cid=&id=0
Old 02-08-2006, 04:44 PM
spherical ends
Hello
Thank you very much Triaged for that information. I appreciate it very much
take care
Tom
8.8 Ford rear end in my 79 G body Malibu 79 Malibu327 Transmission - Rearend 4 05-20-2007 02:26 PM
GRRRRRRRRRR....Front end work.... wickedwitchinak Suspension - Brakes - Steering 17 09-28-2004 11:16 AM
u joint end caps Tissue Transmission - Rearend 6 07-02-2004 10:27 PM
Rear End Gunk? MrChevyDC3 Transmission - Rearend 2 02-19-2004 05:48 PM
79 Suburban Ball Joint change Help!!! mr_chickenhead Suspension - Brakes - Steering 2 01-09-2003 08:08 PM
