Also on the bottom run a flat washer big enough so if you have a failure it will not fall off and leave you steering one wheel. Both NHRA and IHRA have this in the rule book to solve the issue. DON'T BUY CHEAP HEIMS they are on your steering or suspension and you really need those two things to stay intact for the ride.
Mike |
https://secure1.securehosting.us/jer...%26%20Bushings
Scroll down to where it says "safety washers". They also have the dust boots. I prefer to use 3-piece teflon lined rod ends from Aurora or if you have the cash NHBB. I am not a big fan of either swedged 2-piece or loader slot 2-piece rod ends. Here is some more good info http://www.corner-carvers.com/forums...ad.php?t=31646 |
| whats the safe running temperature for air a compressor? | montea | Garage - Tools | 4 | 09-21-2006 04:16 PM |
| safe rpm for 406 | onebad98z | Engine | 6 | 03-18-2004 10:33 PM |
| Are WHEEL SPACERS safe? | MuscleBlock81 | Transmission - Rearend | 14 | 01-27-2004 11:19 AM |
| Are Mustang II Crossmembers Safe? | Jon | Suspension - Brakes - Steering | 14 | 10-17-2003 12:43 PM |
| How thick (filler) is safe? | unstable | Body - Exterior | 3 | 10-15-2003 08:05 PM |
