heli-coil for starter bolt hole repair - Hot Rod Forum : Hotrodders Bulletin Board
Old 07-10-2008, 09:56 AM
GMR GMR is offline
The outermost starter bolt hole on my sbc 350 (1970) seems to have been drilled out and tapped (at least partially) to 7/16. Can a heli-coil be used to restore it to 3/8?
I've read instructions for a 3/8 heli-coil kit and it says to use a 25/64 drill bit. That's smaller than 7/16. So it seems the 7/16 hole is too big for the 3/8 insert to seat properly.
If I can't reduce the threads back to 3/8 somehow, I guess I'll have to heli-coil the hole to 7/16 and drill out the starter from 3/8 to 7/16.
I've heard about a starter brace. I have a GMPP mini starter. How would I attach a starter brace?
Old 07-10-2008, 11:22 AM
Frisco's Avatar
Glad To Be Here
Probably not unless the 7/16 tapped hole is not too deep. Then you may be able to install a heli-coil deeper and use a longer bolt.
You might consider using a "thread insert". They will work in situations where a heli-coil can not be used. I prefer heli-coils when they can be fitted.
Old 07-11-2008, 07:23 AM
GMR GMR is offline
Thankyou for your suggestion Frisco.
Old 07-11-2008, 08:59 AM
There are many brands of thread inserts, one brand name is KeenSert. You can buy them at McMaster Carr (www.mcmaster.com) among other places. They are thicker wall than helicoils. The other big advantage of a thread insert like this is that they typically have locking tabs that are tapped into place after the insert is installed. This prevents the insert backing out problem that is common with helicoils.
Old 07-11-2008, 07:18 PM
GMR GMR is offline
Joe, thanks. I did find some info on keenserts and also timeserts after Frisco mentioned thread inserts. As a matter of fact, I believe I saw a post from you mentioning keensert in reply to someone else's question, while I was researching thread inserts.
Bolt Strength Question jamnut Engine 16 03-30-2005 07:11 AM
Ever work on the impossible? johnsongrass1 Hotrodders' Lounge 16 08-20-2003 01:59 PM
Small Block Chevy starter bolt hole Rad Ray Engine 4 03-10-2003 07:14 PM
bolt hole stripped holding carb down impala dreaming Engine 12 12-20-2002 05:41 PM
engine bolt hole to bellhousing is broken, is it ok? 66StangBoy Engine 6 11-06-2002 05:25 PM
