Hella halogen conversion kit legal to use in US? - Hot Rod Forum : Hotrodders Bulletin Board
Old 08-02-2012, 03:44 PM
russ69coupe's Avatar
Last journal entry: starting to go the right direction
I was planning on using these
Amazon.com: HELLA 002850811 135mm H4 High/Low Beam Halogen Conversion Headlamp Kit: Automotive Amazon.com: HELLA 002850811 135mm H4 High/Low Beam Halogen Conversion Headlamp Kit: Automotive
but then I noticed that it says "Lamps are ECE compliant and legal for on-road use only in Canada" .
Is this a real concern, or should I just use them anyway? This will be on a summer daily driver car that will see night use, I work nights.
Thanks,
Russ
Old 08-02-2012, 05:46 PM
bigdog7373's Avatar
Of course it's fast
I wouldn't worry about it. Just use them, i highly doubt anyone will bother you unless youre driving around with lights as bright as the sun.
It's not those blue lights though right? I freaking hate those things. Everyone around my area is buying those blue lights now, it looks like theres 1000 cops following me everywhere and they look horrible.
Old 08-02-2012, 05:47 PM
It isn't supposed to be those, I hate them myself.
Thanks,
Russ
Old 08-02-2012, 06:35 PM
Wiki Edits: 31
There probably not 'legal' because there not US DOT certified.H4 lights are legal at 35W
These are DOT approved If you want that. Just Ebay the chrome housings
Drag Specialties 5-3/4 Inch Headlight with Lense - H4 Bulb Bottom Mount - DS280035
Old 08-12-2012, 11:27 AM
The Hella H4 headlights are great. I replaced my sealed beam headlights with the Hella type three years ago and will never go back. The big thing is getting them aimed properly. Go to Daniel Stern Lighting Consultancy and Supply for instructions on aiming your E-code headlights. You can also get brighter bulbs there ( I use the 85/80 instead of a standard DOT 60/55) you can really light up the night.
Old 08-15-2012, 05:56 PM
E-code headlights have a different beam pattern because in many countries they drive on the other side of the road.
Old 08-17-2012, 06:58 AM
302 Z28's Avatar
Exactly and when you use them in the U.S. you blind oncoming drivers.
Vince
Halogen conversion dim drchip Electrical 21 07-29-2011 07:25 PM
points conversion kit chevelle_502 Electrical 27 03-25-2011 02:06 PM
Efi conversion/kit bamacj Engine 10 01-29-2006 07:36 AM
Conversion Brake Kit djdress Suspension - Brakes - Steering 3 01-31-2005 06:01 AM
engine conversion kit chris944 Introduce Yourself 1 09-04-2004 10:39 PM
