Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Hello
Thread: Hello
Old 10-19-2003, 02:52 PM
Kaylah Kaylah is offline
former member of
So what you are saying is you have an original Boss 302? Really rare piece of iron for sure. It was only made for a year (between 2 model years) so you have a 69 1/2 through 70 1/2. The way to check if its a Boss 302 for sure is to see if the intake and exhaust valves are "canted" (sitting "kitty-cornered" to each other). If they are, then you will also have 8 valve cover bolts. That would be a very nice find. If the valves are in a "straight-line" then you have a windsor that has been ported and polished (probably). This will have only 6 valve cover bolts.
BTW this is the "head design" that is used to make a 351-"Clevor" which is a Windsor with Cleveland heads.
