hello - Hot Rod Forum : Hotrodders Bulletin Board
Old 11-09-2005, 02:29 PM
hello
hello i have a 65 nova and i am doing arestoration on ait and i wanna know how to remove the ignition lock of the dash please help thanks
Old 11-09-2005, 05:53 PM
66 T-Bird's Avatar
~Low Budget Baby~
hey welcome to the forum happy first post. i would recommend a large hammer and a sawzall lol, i have no clue what so ever but i'm sure sombody will help you there's a bunch of really knowlegable people here (me not being one of those people) hope you like it
Old 11-09-2005, 06:08 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Been a long while, but I think that switch has a bezel that unscrews with the aid of a special General Misery tool..
Does the ring have 2 tiny holes in it? If so this is where the tool inserts.
Snap ring pliers sometimes will work, (be careful not to damage the chrome/dash from slips, use duct tape around it..) Or you could make one to fit the ring to get it off..
Doc
Aftermarket Solutions
Electronic & Electrical
Innovations
Old 11-10-2005, 02:43 AM
Look at the faceplate of the lock cylinder where the key goes. Is there a tiny hole in it? If so, you need to find a piece of wire that will fit into that hole. A partially straightened paper clip will do. Put the key in, turn it to ACC (counterclockwise), then push the wire into the hole. Some springy resistance is normal. While the wire's in, turn the key counterclockwise some more. You should then be able to pull it out. You may have to jiggle it some during that last step. A good hosing with spray lube can also help.
Old 11-12-2005, 06:38 PM
65 nova
hello i have a 65 nova and i am trying to remove the heater cables and they wont come off how do i removve them? do you know where i might be able to get new ones?
Old 11-12-2005, 07:47 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Which end are you trying to remove?
The cables should be held in place with a compression washer on each, just remove that, and slide the end off..
As far as new cables, I should think you can order them through any good parts house.
Doc
Innovations
Old 11-13-2005, 02:49 PM
65 nova
how do u remove those washer things? with out breaking them?
Old 11-13-2005, 05:26 PM
docvette's Avatar
Wiki Edits: 12
Doc here,
Just carefully squeeze with a pair of pliers, and pull the washer off.
Doc
Innovations
