Hello all... early Ford dist swap - Hot Rod Forum : Hotrodders Bulletin Board
Old 06-27-2012, 07:04 PM
I have a 54 ford car 239 eng. trying to put a 1960 ford dist. will this work in this 239? the 239 has got a slot dist.rod in it now so i fount a hex rod that will work in the 1960 dist. how long will it need to be to work??? can i put the dist. in a see how it needs to be to fit on the oil pump it is 8'' long. the gear on the 60 dist.is bigger will the old one fit back on it too?
thanks i hope you can under stain this
thanks for your HELP ON THIS Bob t
Old 06-27-2012, 07:59 PM
S10 Racer's Avatar
http://www.warsprints.com
Last journal entry: W.A.R. (Wingless Auto Racing) Sprint Car Racing
What size motor out of the 1960?
Old 06-27-2012, 09:04 PM
1960 dist.
it was a 289 ford eng. 1960
thanks your help! bt
Old 06-27-2012, 09:14 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
If your 289 distributor uses an O-ring to seal it, the conversion can work. You will need to replace the 289 gear. If your car is 6V, the condenser will need to be changed to a 6V one for the 289 distributor, I believe.
Early Ford Spindles fitting early Ford axles pasadenahotrod Suspension - Brakes - Steering 3 08-14-2012 07:20 PM
early comet engine swap (or early mustang) REALGONEKATT Engine 14 11-04-2007 06:15 PM
Small Block Ford Dist. bushings Capt. Zorro Engine 4 09-15-2007 04:30 AM
Late/small style Dist on early chevy upstand2 Electrical 1 06-19-2006 04:29 PM
changing from points dist. to electornic dist. what to change? IHAVECHEVYPARTS Electrical 1 12-21-2002 09:20 AM
