hello fellow rodders - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-01-2013, 03:31 PM
name is bob i have a 64 c10 all original it seems to skip time a little im in the process of changing cam,lifters timing gears.any recommendations on cam? and can i hot it up a tad bit? thanks all.
Old 02-01-2013, 04:48 PM
welcome
Hi Bob,
Of course you can liven up the cam a little. Depends on how you use your truck, but if you're just looking for a little better throttle response and low end torque you can something along the lines of a Comp Cam High Energy cam...great little cam. I use them in a couple of my work trucks and they perform better then stock and actually seem to have improved fuel mileage also. But...it really doesn't have that lopey idle...pretty smooth with just a barely audible skip in the idle
The Following User Says Thank You to snakebit68 For This Useful Post:
64 c10 bobby (02-01-2013)
Old 02-01-2013, 06:22 PM
RWENUTS's Avatar
WElcome Bobby!!
Six banger or smallblock.
The Following User Says Thank You to RWENUTS For This Useful Post:
Old 02-01-2013, 08:39 PM
vinniekq2's Avatar
welcome to the forum.I hope you enjoy it here.Tell us about your truck and what you expect? Im sure we can toss a few good ideas out there.
also state what you are looking for in the way of performance?
The Following User Says Thank You to vinniekq2 For This Useful Post:
Old 02-01-2013, 09:44 PM
its a six 230 daily driver.
Old 02-01-2013, 09:56 PM
vinnie as of now just keeping it running with a little performance its already lowered but i definitley need new springs im thinking as low as possible without using notches or drop spindles you know the rolling project.lol.but definitley cam lifters and timing gears head was rebuilt lastyear.thanks any and all suggestions and guidance would be greatly appreciated
Old 02-01-2013, 09:57 PM
vinniekq2's Avatar
The six is a great engine.It does not make huge power due to the head design.Open up the exhaust and if you can find a 4 bbl intake that helps a lot.
Old 02-02-2013, 04:22 AM
Hi Bob, & welcome !!!
Try linking Clifford Performance :: Make 6 = 8 they truly are 6 banger performance wizards. They have oodles of 64 & up Chevy 6 hop up parts.
Hope that helps . Rick
Old 02-02-2013, 09:24 AM
RWENUTS's Avatar
More six banger stuff.
My old 65 with a 230 I ran a set of Langdon's cast iron headers, HEI, and Offy intake and holley 350 2 bbl.
Greatest improvement was from the HEI.
Langdon's Stovebolt Engine Co. | Specializing in GM 6 Cylinder High Performance Parts
Old 02-02-2013, 09:41 AM
hotrod
Ibet that HEI really helped. Doubled the voltage to them plugs probably improved fuel economy too...well maybe not with that Offie intake. LOL
Old 02-02-2013, 10:35 AM
RWENUTS's Avatar
Truck!!
About as aerodynamic as a barn!!
Mileage??
What's that??? LOL!!!
Old 02-02-2013, 11:15 AM
BigEd36's Avatar
In addition to Clifford Performance and Langdon's Stovebolt Engine Co. already mentioned here are some other sites devoted to inline 6 performance and parts.
Inliners International devoted to all Inline powered vehicles
Hotsixes.com
Autowerks - 250/292 products
Info about lump heads for the inline sixes
Bobby, don't discount the capabilities of the Chevy sixes, they're great little engines. Cams and other parts are available to really make 'em go! For an example, the attachment is a screen shot from the Howards Cams catalog with the listings for 194, 230, and 250 sixes. (In these listings the "Note 1" at the right means "Stock (O.E.) valve springs can not be used".
Old 02-02-2013, 11:28 AM
6 banger
Hey...honestly there are a couple of guys running straight sixes on their rail dragsters and putting them into the 8's in the 1/4. Thats impressive!
Old 02-02-2013, 11:50 AM
BigEd36's Avatar
The mighty six has turned 8.44 at 160 mph in a '36 Chevy pickup! On DOT tires!
Hello fellow Rodders! Hellnote1 Introduce Yourself 1 10-05-2010 06:59 PM
hello fellow rodders keith davis Introduce Yourself 1 09-16-2010 04:07 PM
Hello, To fellow rodders JDG 38 pontiac Introduce Yourself 1 12-30-2006 06:28 PM
Hello fellow rodders! 34hiboy Introduce Yourself 2 03-22-2006 01:57 PM
Hello to all fellow rodders. bigshow2 Introduce Yourself 2 09-14-2005 03:51 PM
