Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - Hello...SBC valve adjustment
Old 01-04-2013, 09:09 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Using TDC will work most times, unless the cam is way big or it has very long clearance ramps, like the Duntov 30-30 cam.
If TDC is going to be used, at least verify that the lifters are not on the clearance ramps by setting them at TDC then check using the EO/IC method. If there's no change in the lash, you're good to go.
The Following User Says Thank You to cobalt327 For This Useful Post:
Thomas Sutton (01-04-2013)
