Hello...SBC valve adjustment - Hot Rod Forum : Hotrodders Bulletin Board
Old 12-31-2012, 09:05 PM
I hope that i can get some informaion about my engine,i:m tring to see how to ajust the vales on my chevy sb 355 i have a soild cam not sure about the engine or the heads,tu
Old 12-31-2012, 09:34 PM
carolinacustoms's Avatar
Automotive Extraordinaire
Welcome to the forum and Happy New Year. I'm sure one of the Chevy guys will be along in a few to help you out. I was going to try to explain it, but realized it would probably take me two or three pages and I'm sure someone can be a lot more informative in a much shorter post LOL. A little more info may be helpful to them though. Have you ever adjusted valves on a solid lift cam? Or a Chevrolet based engine?
Old 01-01-2013, 08:55 AM
delawarebill's Avatar
valve adj
try finding a manual that tell u what lifter is at bdc at TDC on the balancer then u adj about 1/2 the lifters then turn the crank one full turn and do the remaining lifters.. u will need to know the cold feeler gage setting. tighten the rocker down till u have a snug fit when pulling it out. just don't over tighten the rocker, that will equal a bent push rod. i know a motors manual gives u this info.. keep in mind when u fire it up it will click and always have a small clicking. there solid not hyd..
The Following User Says Thank You to delawarebill For This Useful Post:
Thomas Sutton (01-04-2013)
Old 01-01-2013, 09:02 AM
bondo's Avatar
Ayuh,.... All cams are solid,.... but What lifters are ya usin',..??
The Following User Says Thank You to bondo For This Useful Post:
Old 01-01-2013, 09:06 AM
i thought he was talk'n solid lifter cam..
sure hope so.. or thats my first mistake... today that is and its early...
Old 01-02-2013, 12:00 AM
Thanks delawarebill, also i have solid lifter. there:s alot of information i did:nt get when i bought this race car,however i have some. I could be wrong but i think i can use ur infom. thanks again ,and have a healthy new year.
Old 01-02-2013, 12:37 AM
techinspector1's Avatar
Wiki Edits: 326
https://www.youtube.com/watch?v=3gMYWLMAzao
The Following User Says Thank You to techinspector1 For This Useful Post:
Old 01-02-2013, 10:18 AM
1971BB427's Avatar
One issue you'll need is to determine valve lash on your engine's solid lifter setup. If you were using hydraulics the lash are all the same, but solids require different lash from manufacturer's specs. The old Duntov 30-30 was set as the name indicates, .030" lash intake/exhaust.
Some mfg. spec similar clearances, but some spec less. Most don't spec more than .030" clearance. Most modern Comp Cams are .022" lash. You could get somewhere around that lash and hope it's close enough.
The Following User Says Thank You to 1971BB427 For This Useful Post:
Old 01-02-2013, 01:54 PM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Adjusting solid lifters
Good luck.
The Following User Says Thank You to cobalt327 For This Useful Post:
Old 01-04-2013, 05:31 AM
Adjusting Solid Lifters
Aside from getting the valve lash correct, the procedure per cylinder is crucial. I have tried every procedure, but find the best and easiest for myself was an individual firing order adjustment rotating the crank, starting at TDC and proceeding to the next firing cylinder. Like I said, I start at TDC on the crank and adjust No.1 firing cylinder valves ( both intake and exhaust ) to specs. I then turn the crank 1/4 turn in direction of firing rotation and adjust the valves for the No. 2 firing cylinder. Continue this through the cylinders until you are back at TDC and you are good to go. This works for all 4,6,8 cylinders and I find keeps things a little simpler. Good luck.
The Following User Says Thank You to DeeW For This Useful Post:
Old 01-04-2013, 09:09 AM
cobalt327's Avatar
WFO
Wiki Edits: 1616
Using TDC will work most times, unless the cam is way big or it has very long clearance ramps, like the Duntov 30-30 cam.
If TDC is going to be used, at least verify that the lifters are not on the clearance ramps by setting them at TDC then check using the EO/IC method. If there's no change in the lash, you're good to go.
Old 01-04-2013, 09:38 AM
Cobalt 327 Valuable, accurate information.
sbc valve adjustment problem 4thgencamaro383 Engine 2 08-09-2011 11:16 PM
Sbc compression and valve adjustment 99 to Life Engine 4 04-26-2011 04:51 PM
valve adjustment sbc Vegaman1 Engine 2 11-12-2010 03:09 PM
sbc hydraulic valve adjustment hottrodz Engine 10 12-16-2006 10:46 PM
Questions on valve adjustment on a sbc Frankoholic78 Engine 4 06-01-2006 09:07 PM
