LinkBack | Thread Tools |
Nobler, give me a TOTAL length dimension !
That is from the extreme end of the male M14 x1.5 that screws into the rack bar, to the extreme end of the male M14 x 1.5 thread on the tie rod adjuster end. I know that sounds rather odd, but that is how these tie rods lengths are specified in the TRW chassis parts book. I have two pages of lengths listed from 5.42 inches to 15.75 inches. |
do you have drawings of your planned setup? it worries me that such a short rack may make you end up with too long tie rods which will give your suspension a bad case of bump-steer.
The tie rods are the same length as the lower wishbones, and just as importantly are located at the same height as the lower wishbones. There will be zero bump steer, Nobler knows EXACTLY what he is doing. |
hello again
hello, thanks for the bump steer concern.
what has transpired is, i took delivery today of a megane tie rod end, now i thought i'd need something 270ishmm end to end, I was kind of measuring from the lower regions of the lower pivot, on the line through to the top. the meganne worked out at about 245mm, of course it was only when i had fitted the tie rod to the rack, and the rod end to the rod, fit that into the spindle, then came back over with the lower arm, that I realised i needed to raise the rack up, in order to clear the lower arm, with the gaiter, thus moving the steering rod ball out, taking up the difference, another fluke as it has turned out exact. takes another inch from the overal width too!!! anyone have any 6j torque thrusts in ford 4.5 - a pair. also thanks fro the heads up on the 8 - 1 =7.15 degrees, as its cross-member time, SO, if the cross-member is 4 inches wide, there needs to be 1/2 inchdiffernce front to back of the 4'' piece of steel, to acheive a dive angle of 3.5-ish -seems a tad extreme on a car with a 92 inch wheel base. for some reason I had 3-4mm over the 4 inches - 100mm = 1/4 inch over 4 =1.75 degrees might stick a little more in now!!! -recap - using 3 inch by 2, will stick with the 4ish mm. =thanks. Last edited by nobler; 04-06-2011 at 05:36 PM. |
![]() all good, turns out track will be a tad narrower too. renault megane. only concerns now are steering arm length verses 4-1 ration and throw, 59mm each way p.s. gaiter divet = perfecto too!!!! |
I did check the major and minor taper diameters were the same as the Mustang 2 taper diameters. As you have just discovered, that small detail is rather important. |
| ball joint taper reamer | tomslik | Suspension - Brakes - Steering | 16 | 07-02-2010 08:13 PM |
| pics of my mustang at the track | old fords | Hotrodders' Lounge | 6 | 05-23-2010 11:02 PM |
| Using 18 degree pistons in a 23 degree block | S10 Racer | Engine | 2 | 03-11-2008 03:52 AM |
| Converting wheel bearings taper to ball | saltybob | Suspension - Brakes - Steering | 2 | 10-11-2007 10:45 PM |
| Cylinder Taper | chumbucket | Engine | 2 | 04-11-2006 10:45 AM |
