Help!!! - Hot Rod Forum : Hotrodders Bulletin Board
Old 02-24-2007, 09:12 AM
Last journal entry: comming along
Help!!!
I finished the brakelines on my 37 Ford. I tightened up on everything. I bled the master. Now pushing on the pedal I have leaks at both valves, and the porp. valve. I took it off and looked it over, and it looked ok. I put it back together, and it still drips a little. Can I use teflon tape on the threads?? or some sort of pipe dope?? Thanks.. Al
Old 02-24-2007, 09:23 AM
Brake lines seal at the flare not at the threads. Thread sealer should not be used. If tightening doesn't stop the leaks new flares will have to be made.
Old 02-24-2007, 09:40 AM
I bought brake lines already done, so that I wouldn't run into problems. Would you suggest then that I build my own lines?? Also why is one end of the line have a long threaded end, and the other side is small?? Does it make any difference how I installed it??
Old 02-24-2007, 09:41 AM
powerrodsmike's Avatar
Wiki Edits: 161
No . Do not use any sealant on those threads. A properly flared tube fitting and new fittings will seal.
The threads on a new tapered fitting for automotive brake system use is of the "dryseal" type.(nptf)
This threadform is made so that the crest of the thread on the male fitting actually cuts into root of the thread of the female fitting, displacing metal, and creating a mechanical seal.
This type of fitting was developed to need no sealant, as the higher pressures involved in hydraulic systems commonly ejected the sealant from the joint when put to use. Ejected sealant can no longer seal. Teflon tape can get stuck in valves and is definatly a no no.
Sometimes reusing those types of fittings will result in leaks.
The cone at the bottom of a female inverted flare type fitting will also be prone to leak if it has been used, overtightened or the double flare is improperly done.
Those are the things you need to check.
The longer length tube nut is provided on those pre flared lines to use in limited access areas, so You can get at the hex easier.
It makes no difference where they are used.
I would trust the factory flares on the tubes you bought, they are usually better than the home done ones.
Hope this helps,
Mikey
BE different....ACT normal.
Old 02-24-2007, 09:52 AM
Henry Highrise's Avatar
Lost in the 60's
Wiki Edits: 4
Overtightening is the cause of a lot of brake system leaks. I usually snug good and check for leaks ....if I have one I tighten just a little each time untill the leak stops. Over tightening can ruin the flare as well as the inverted fitting.
Old 02-24-2007, 09:53 AM
I did have to use reducers on the valves. That is what Speedway Motors suggested that I do. Do you think that maybe the reducers that I put in may have been put in wrong?? I just screwed them in untill tight, then screwed in the brake line.. All of my other conections work just fine. I had to use a few unions with th lines, and have no leake at all there.
Old 02-24-2007, 09:59 AM
So then I should take apart those fittings that leak and look for bent female ends??
Old 02-24-2007, 10:10 AM
Lost in the 60's
Wiki Edits: 4
Did you use inverted flare reducers? That may be your problem...you might have used the wrong type reducers.
Old 02-24-2007, 01:11 PM
Not sure. I ordered from Speedway Motors the front valves for the disc brakes. I was told I needed because I was running two lines two 2psi valves. I also needed these reducers for the valves as well. They sent me 4 reducers with the valves. I just replaced the one brake line that was leaking. I must have installed it at a slight angle. I looked at the end, and it was slightly bent. The only thing right now is where one of the reducers goes into the valve. I pumped the brakes a good 5 times. There was just a damp spot, but that could have been from before, and I can't get all of the fluid off. I tried to dry it off, and I only get it damp once in a while. Not all the time. I will try to give it another tug. If that doesn't work would you suggest that I pull that valve and change the reducer?? There is no drip there, and that is the only spot that is now wet. If the valve looks bad inside would you think I should block off one of the lines, and put a "T" fitting into the other line?? Thanks.. Al
Old 02-24-2007, 02:07 PM
66GMC's Avatar
Get in, sit down, hang on
Last journal entry: Cab Removal
I read thru some of your previous posts, where you had experienced some trouble with "through the frame" adaptors ... which leads me to believe that you probably have a lot of connections.
More connections = more places for leaks to occur ... and brake fluid will often migrate downward on the outside of the tube.
Wipe the whole system down with an absorbent rag, followed by a liberal spraying of brake clean to make sure everything is clean and dry. Have someone else push on and hold the brake pedal, while you (starting at the top) examine for leaks, bubbling sounds, etc.
After you have pinpointed the fitting(s) that are leaking ... the next question is "Why are they leaking?"
As others have implied, you have to make sure that all fittings are correctly mated to each other. It's common to see people trying to use *pipe-thread* fittings where the should be using *tube-thread* fittings (or vice-versa).
Look for rolled/ stripped / cross-threaded threads at all connections.
Check all flared ends on all tubes for cracks ... both on the contact area and behind the flare (under the nut).
HTH,
Don
Old 02-24-2007, 02:27 PM
Lots of conections. I did wipe down everything. There is now only one spot that is damp. It is at one of the reducers that goes into one of the valves for the front. It doesn't drip though. It gets damp from time to time. No one here to hold the brakes down for me. I have been pumping them then going to check the different connections. I don't have the body on yet, so it makes it somewhat easier. Would you suggest that I crap the whole system that I have, and get a roll of line and buy the double flaring tool and redo the job?? I already have a tubing bender. Another thing that I am not sure of. In the front I put the brake line over the frame. Should I have put it under the frame?? I want it done right. I can only get certain lengths of line. I can only get 12,20,36,48,and 51" lengths. Thanks
Old 02-24-2007, 04:49 PM
66GMC's Avatar
Well, as suggested earlier ... I'd investigate that connection to see WHY it is leaking.
I was trying to point out that the fluid MIGHT be coming from a leaking connection above.
Are you telling me that your entire brake line system is built from shorter peices joined together?
Old 02-24-2007, 06:22 PM
Well kind of. I used to lines on the rear. That was how it was to start with. I just replaced it is all. I then went to the rubber hose that goes up to the frame. From there it goes about 12" to a 10psi valve. From there it goes another 20" to the prop. valve. Then 36" to the back of the master. The fronts started at the master with a "T". I left both line on it and ran 12" on one side, and 20" from the other to both 2psi valves. From there one side has a 36" line that goes to a 12" line. Then from another union to a 20" that goes over the frame to the mount that is on the other side to the brake hose. The other line from the 2psi valve goes to a 12" line to a union that then goes to a 51" line that goes over thbe frame to the other rubber hose. I just came home from church and found that there is a leak at one of the reducers that goes to one of the 2psi valves. I know that the reducer is at the bottom. I don't think I can turn it in any farther. I could just remove it from the "T" and "T" it off further down the line to the other side. I think I can buy another reducer in town, but I don't want to fork out another $32. for another valve.
