help?? - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-09-2007, 09:52 PM
sprecher48's Avatar
Oddo nut
Last wiki edit: VW engine basics
Last journal entry: note from the sandpit vol.#3
Location: sunny south(maybe rainy,haven't looked outside today) florida
Wiki Edits: 10
help??
I am about to start on my dream,(1950ford 2dr.) I have a 1976 mustangII front suspension(out of a v8 car) what is it going take to put this under my shoebox?
Old 04-11-2007, 01:58 PM
WELCOME to Hotrodders.com
As a Moderator here ... I want to be the first to WELCOME you here. Unfortunately ... the 49 to 53 Fords do not accept a Mustang II IFS very well. They were already independent front suspension and the frame does not adapt well. There are front stubs being made to remedy this. A GM clip is too wide IMHO ...
Click on this ...
http://www.fatmanfab.com/07page6.htm
As a Moderator here, I try NOT to recommend specific brands ... read the link and make up your mind ...
Again WELCOME
Deuce ... Moderator
Old 04-11-2007, 02:34 PM
Wiki Edits: 31
Y not just upgrade the stock front end with disc brakes? adapt a power rack and pinion into the mix ( keeping the original front end, just taking out the center link ect... ), you'll have good results with little trouble
