help
Hi this is Brandon. i have a 1977 ford with a 390. i just put a 204 214 cam in it. and a 1406 carb. and at high rpm it cuts out i put new jets.092 in p and .089 in s. and springs are a 7. timed it played with the air fuel cant get it to run right can you help?
Welcome to the site, You need to post this in the engine section, You will get better responses there then in the interior section.
Have you checked to make sure it's not cross wired? and you could have a vacuum leak also. JMO Cole |
no vacuum leak i have replaced everything what do you mean cross wired
Make sure it has the plug wires in the right order.
Cole |
yeah it does
Let's move this to Engine.
Dan
__________________________________ No one lives forever, the trick is creating something that will. __________________________________ |
2500 3000 like you are pulling a hill
yeah because you can here it come back in the carb
runs good if you push the gas slow but if you push hard like your pulling a hill or racing it bogs down and pops throw the carb its rebuilt and tuned up
My car was sputtering whenever i jumped on it and i put an inline fuel pressure gauge. 3.5-4.5psi! I put a carter pump and holley regulator wala 5.5psi! All fixed Also whats the timing at. Initial and mechanical. Is the vacuum advance ported or full manifold? |
timing is at 14 at an idle vacuum advance was ported but is not hooked up right now because it wont run at all with it. i had it checked and its good but over advance when its plugged in they told me to find out whats wrong then fix that.
