Hot Rod Forum : Hotrodders Bulletin Board - View Single Post - help
Thread: help
Old 10-02-2002, 08:38 PM
Halloweenking's Avatar
Halloweenking Halloweenking is offline
Fantastically cannibalistic!
Carguy, just factor in how much work it is for you and how much you will enjoy it. If its hard work, hard on your body factor that in. On a complete color change I charge anywhere from 1000+ depending on graphic, flame, or any customized variation. Metalic colors are much harder to paint and since your doing a full color change you'll need to do doorjams and etc so it won't be an easy job. I say at least $500 for the job, more if you yourself is doing all the work. 500-700 without supplies sounds fair in my area, but everything here is priced a bit higher.
[ October 03, 2002: Message edited by: Halloweenking ]</p>
