Help 1969 mustang - Hot Rod Forum : Hotrodders Bulletin Board
Old 04-18-2009, 05:50 PM
Help 1969 mustang
What tool do you use to seporate the power steering control valve from the pitman arm. or do you have to remove the pitman arm from the gear box and then remove the control valve from the pitman arm. What tool do you use and do you have to press the new control valve on the pitman arm or will it just slide in?
Old 04-27-2009, 06:13 PM
get a motors repair manual for that vintage, or go to a library, it would be hard for 1 to explain, where the manual has a good vew and walks you threw.it is easy if you follow the inst. cliff
Old 04-27-2009, 08:50 PM
eloc431962's Avatar
Evil Wicked Mean And Nasty
Wiki Edits: 37
Did he ever get it off yet. if not soak it down with pb blaster or something along the same line.they make pullers also rent one if you dont have one put pressure on it with the puller.take a hammer and hit it sometimes hit it pretty hard .knock it loose.some people just take a BFH a knock the fire out of it till it comes loose. you probably still need to invest in a book it will always come in handy. Cole
Re: Body work - 1969 Ford Mustang fastback BOBBY MAN Body - Exterior 9 12-21-2005 08:20 PM
1969 Mustang AOD Swap RalphC Transmission - Rearend 1 08-18-2005 12:02 AM
429,460 in 1969 mustang mach 1 servant70131 Engine 5 07-14-2005 10:05 PM
1969 mustang help nicowarrenrogers Suspension - Brakes - Steering 2 07-27-2004 01:34 AM
1969 Mustang 302 with E40d? tribalstitch Transmission - Rearend 1 01-28-2004 07:48 PM
